New Build Verification
ohlmsjm
APPROXIMATE PURCHASE DATE: Next 2 weeks
BUDGET RANGE: Less than $2400
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming only, minor surfing
PARTS NOT REQUIRED: 24" NEC LCD2490WUXi, Microsoft Natural Keyboard, Klipsch Speakers 5.1, Razer DeathAdder Mouse, Logitech USB Microphone
PREFERRED WEBSITE(S) FOR PARTS]: newegg.com
COUNTRY OF ORIGIN: US
PARTS PREFERENCES: See list of possible components below
OVERCLOCKING: No
SLI OR CROSSFIRE: Maybe
MONITOR RESOLUTION: 1920x1200+
ADDITIONAL COMMENTS: I'm looking for some solid feedback on my component choices and make sure I don't miss any "gotchas" that might hinder the build or performance of the machine.
CPU:Intel Core i7 920 Nehalem 2.66GHz LGA 1366 130W Quad-Core Processor Model BX80601920 - Retail
MOTHERBOARD:ASUS P6T Deluxe V2 LGA 1366 Intel X58 ATX Intel Motherboard - Retail
MEMORY:CORSAIR DOMINATOR 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model TR3X6G1600C8D - Retail
VIDEO CARD:SAPPHIRE 100281SR Radeon HD 5870 (Cypress XT) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video ... - Retail Crossfire down the road
OR
EVGA 017-P3-1295-AR CO-OP Edition GeForce GTX 295 1792MB 896 (448 x 2)-bit DDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported ... - Retail SLI down the road
POWER SUPPLY:CORSAIR CMPSU-1000HX 1000W ATX12V 2.2 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS Certified Modular Active PFC Compatible ... - Retail
CASE:Corsair Obsidian Series 800D CC800DW Black Aluminum / Steel ATX Full Tower Computer Case - Retail
HEATSINK/COOLING:XIGMATEK Intel Core i7 compatible Dark Knight-S1283V 120mm Long Life Bearing CPU Cooler - Retail
and
Arctic Silver 5 Thermal Compound - OEM
SOUND:Creative 70SB088000004 7.1 Channels PCI Express 1x Interface PCI Express Sound Blaster X-Fi Titanium - Retail
STORAGE 1:Intel X25-M SSDSA2MH080G1 80GB SATA II MLC Internal Solid state disk (SSD) - OEM
STORAGE 2:SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM
STORAGE 3:SAMSUNG DVD Burner Black SATA Model SH-S223L LightScribe Support - OEM
See anything that I might be missing or might change?
lt_shiro,
Thanks for the feedback. I'm curious as to why you chose that motherboard over the ASUS and were you suggesting 12G of memory?
Asus board
-layout is bad
-price
As for the memory, why not? if you are willing to spend $180 on 6 GB kit, 12 GB for $70 more isn't that bad of a deal.
Asus board
-layout is bad
-price
I've been scouring the forums and the web trying to clarify your statement here about the layout on the ASUS board being bad. Would you be kind enough to clarify Shiro?
Thanks again!
if you install crossfire or SLi setup
you will only 1 PCI and x1 slot with Asus layout
evga x58 depend on which slot you use, there is 1 PCI and 2 x16 slots on the board not in use or blocked.
Why did you choose the P6T Deluxe? What features did it have that you wanted/needed?
Dominators are overpriced and offer no noticeable performance improvement over standard XMS3 or other DDR3-1600 sticks. You won't notice the difference between CL8 and CL9 in your usage.
Ditch the X-Fi, I doubt you need it. Onboard HD Audio is fine, especially for your speakers.
I chose the P6T Deluxe as a recommendation for stability, performance, pricepoint, and SLI/Xfire capability, and the second ethernet port.
I chose a dedicated sound card to hopefully offload some of the CPU since this rig will be for gaming.
What will you be using the second LAN port for? Is that second LAN port worth the extra $50 over the comparable P6T? The P6T is also known for its stability, SLI/CF capability and price.
Oh and sound processing is so minute in terms of CPU usage, you would honestly not notice a performance difference. We're talking less than 1% CPU usage here. So no need for a sound card unless you're an audiophile with a decent speaker setup.
I have no problems with going with the P6T non deluxe, I was questioning the feedback given about the Asus layout vs the EVGA. I haven't made my purchase yet which is why I am here. :)
After reading up on the EVGA board, I'm really leaning that direction since it sounds like the support structure there is well worth it.
I don't think you can go wrong with any of the boards mentioned, as long as you don't mind the prices.
And as Danny mentioned, with onboard HD Audio, there's not much to offload in relation to how fast modern CPUs are these days. ;)
Get this Mushkin 3x2GB DDR3 1600 kit instead of the Corsair Dominators or G.Skill Ripjaws. You don't need "performance" RAM if you aren't going to overclock and you don't need 12GB of RAM to run the latest games.
You could save some more money by going with the OCZ Obsidian 3x2GB DDR3 1600 kit, but its voltage levels are too high for my liking.
Nearly any X58 motherboard would suit your needs with little trouble, so it makes no sense (to me) to spend additional money on "reliable stability" when you won't even use half of the board's available features. Many a computer user has been satisfied with their "basic" P6T (non-Deluxe) board.
