I having problems with the USB connector, Heres quick question. Its a Lian Li-65B, the connector has one solid connector and has the same thing on the same cord doubled (This is the Front Panel USB Cord), I presume you only manually plug in the pins, if the motherboard has some weird USB arrangement, its standard, so can I just use one prearranged version of the plug or match the pins with the pin version? Does this make sense? I can take a picture, if not.
