New Build Tomorrow - Looking for Quick Advice
Noxxville7
Gaming mainly
Would like to keep it around $700 or less
Ontario near London
CPU, RAM, Motherboard, Hard Drive, Case
ASUS 6850EAH video card, Corsair 750HX power supply
6) Will you be overclocking?
Probably a little bit, nothing big in my mind yet
7) 7) What is the max resolution of your monitor? What size is it?
3 22" 1980x1080, generally don't use eyefinity when I game though, just run one monitor
Tomorrow (boxing day)
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? etc.
Crossfire would be nice (just for the option, no plans on running xfire yet), USB 3.0 must have some ports, SATA 6Gb/s would be nice
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Already have Windows 7 Professional 64-bit
I ran through a quick build earlier, my build will likely have to come from Canada Computers (at least partially, have gift cards).
Currently I have this in mind:
Motherboard: Gigabyte GA-Z68X-UD3H-B3
CPU: i5-2500k
RAM: 2x4GB Kingston HyperX 1600MHz (2 sets totalling 16GB, one of the sets is free with the mobo)
Hard Drive: WD 500GB 7200rpm SATA 6GB/s (I want a SSD for the OS, but can't fit it in the budget right now - will be added later)
Case: NZXT Phantom White
I appreciate any input you guys can provide soon, wish I could have got this up earlier but I didn't plan on doing this now. The build listed above totals $700 almost exactly, tax included. Thanks in advance.
I would try for some CL7 ram instead of that CL9 but just a suggestion, you'd probably have to go with 1 gig sticks or 2 gig sticks to find CL7 ram. I buy into the hype that CL actually means something for gamers though there have been articles that say otherwise.
Edit: I would suggest a 32meg buffer on the HD but for a 500 gig HD it may not be necessary for performance sake, however, for gaming the more buffer you throw at it the better. I saw a 150 gig 10k rpm velociraptor : http://www.canadacomputers.com/product_info.php?cPath=15_210_212&item_id=041440 for $60 more or there was a 300 gig raptor for $100 more on that website. Not a bad upgrade option since the HD is the biggest bottleneck.
Edit2: water cooling option http://www.canadacomputers.com/index.php?cPath=8_135 for $50 or so more. I got an H60 and simply screwed in an extra fan in a push and pull configuration, no big mod just simple and it keeps my 1100T at 100 degrees F at idle. However, the H70 performs better due to a better pump and the Antec 920 is actually louder but performs better from reviews, too. In hind sight I may have gotten the 920 because the H60 is whisper quiet, I was worried about sound.
Ditch the RAM: It's rated at 1.65V which means that it has a higher chance of damaging your CPU. Go with RAM rated at 1.5V.
Other than that, looks like a good setup to me.
