New build, Temp/Noise Questions
thatguyX
Built a new rig recently, last build was about 4 years ago. Just wanted to know if these temps sound right, or if there's anything I can do to lower them a bit.
Components:
Intel i7 920 @ 2.667Ghz (no OCing, yet)
Asus P6T Deluxe V2
Corsair Dominator 6GB (3x2) DDR31600
eVGA GTX 285 SC (675Mhz)
Zalman ZM1000-HP PSU
Zalman CNPS9900LED CPU Cooler
All this is housed in a Lian Li PC-60FWB, which has a 140mm front fan @ 800-900rpm and rear 120mm at 1000-1200rpm. I can't figure out how to manually control the fan speed with MB, and I don't know if these fans are limited to those speeds. Lian Li markets them as "quiet fans."
So far (2 days):
CPU IDLE 42-44C \ LOAD (highest seen) 59C
SYS IDLE 34-42C \ LOAD (highest seen) 47C-52C
Are these temps about right? I know the i7 runs hotter than most CPUs; should I try reseating the HSF or give it time to set? Also as for the MB temps, I have no idea where the motherboard temp sensor (suspecting it maybe too close the GTX 285). I also have the PSU mounted right side up (the case has some rails to raise it up about 3/4" for the bottom fan), would it help to mount it upside down potentially pulling hot air down (doesn't make sense to me) and out the back?
Is there anything I can do to quiet this sucker down while lowering temps? The loudest component is of course the GTX285 stock cooler, then the Zalman (used to have an Zalman cooler on an old AMD64 which was undervolted to near silent). I've considered watercooling for less noise and then overclocking, as so far I don't think I need to overclock (yet). Just looking to see what the norm would be, or if something in my rig is causing what I think is somewhat high temps.
Which thermal compound did you use?
Your temps are about right. Keep in mind that the i7 920 is a 130W processor so it runs hotter than the 775 chips. My idle temps are about 38-43*C (depending on ambient) under a TRUE-120 @ 4.0 GHz. Load (100% CPU utilization) temps are 75-79*C.
Hmmm, sounds like 2 much thermal paste. I have a i7 920, with a zalman 9700 and my idle temps are 27C
I won't believe that until I see some photos. What speeds/voltages are you running at?
To the OP: What is your CPU running at? Vcore?
@TeeJay88: I used a small dab approx the size of a grain of rice and then spread it out across the integrated heat spreader only (didn't put anything on the Zalman itself (tried this way as recommended on bit-tech))
@PC_User: Asus AI Suite has the clock speed at 2.677Ghz (133.86x20.0) with a voltage that varies from 1.0800 to 1.2480V.
On a cold boot the SYS temp starts around 34C and then gradually settles around low-mid 40s after some regular-to-gaming use. Also the eVGA Precision tool has the GTX 285 at start-up around 42C, after some use idles around 45-47C, and under load (CoD:WaW 1900x1200 Max settings) 80-81C.
Should I try re-mounting the HSF? Could it be that my PSU (very warm to the touch after gaming) is just causing a build up of heat? I was considering changing out the intake & exhaust fans for maybe Noctua, Aerocool (for the front because of LEDs) or Scythe fans. My goal is to build a rig that is very quiet to silent, I keep the computer on my desk right now, so I can look into the window :lol I want to overclock is to at least 3.0Ghz down the line, but I'm more concerned with getting it to run quieter to my tastes first. I'm considering WC, but it would be a tight fit unless I mounted the radiator ontop of the case (fans pushing on the inside)
Silent water cooling:
Quiet <---> Cheep <---> Effective
Pick any two.
i7 920 Running @ 3.9GHz 1.23v HT/on Turbo/on.
Idle temps with a 4870 and soon to be VREG block.
Load temps. My temps don't change if its 20mins in Prime or 24hrs in Prime. Dead stable. The VREG get's effin hot, hope the water block in the mail will take care of that.
Pretty happy with those temps considering its getting warm here already =/
@Zero82z: I'm measuring these temps off of AI Suite
@billb: I've decided to try to do this in stages, so I guess it's gonna be quiet and effective.
Is this proof. Although i do take into acount that speed fan may not always be spot on.
http://i710.photobucket.com/albums/ww103/TeeJay1988/proof.png
Idle temps are useless anyway, so that doesn't really mean anything.
SpeedFan reports incorrect temperatures due to a different TJMax. My SpeedFan temps are off by 15*C. Try CoreTemp/RealTemp.
