New build suggestions
Daily use, web, HD video, gaming, some photo editing.
$1200 w/ tax and shipping.
3) Where do you live?
Vegas.
CPU, MoBo, RAM, GPU, Cooler, HDD, Case, PSU, DVD.
None.
6) Will you be overclocking?
Yes.
24" LCD, 1920x1200
Within the next week (waiting to see what's available with Memorial day sales).
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
Crossfire, usb 3.0.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Will need to purchase a new copy of Win7 64bit.
My current system is on it's way out and I'm looking for some help/suggestions, to get the most out of my new build.
I've been reading alot of the other posts like this, and have put together a list that stays within my budget( a little bit under it).
Case: Haf 912 - $59.99
MoBo: MSI P67A-GD53 - $149.99
CPU/RAM: Intel I5-2500k,
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 - Combo $291.98
Cooler: H60 - $72.99
HDD: SAMSUNG Spinpoint F3 1TB - $64.99
DVD: SAMSUNG SH-222AB - $20.99
PSU: CORSAIR Enthusiast Series TX650 V2 - $89.99
GPU: MSI R6950 Twin Frozr II OC Radeon HD 6950 2G - $289.99
+ Windows 7 Home Premium SP1 64-bit - $99.99
Cost: $1140.90 + $17.43(shipping) - Total $1158.33.
Is the power supply enough for this build? I would like to get a modular PSU, but I'm not sure what is available that is reliable around the same price point at the TX650 V2.
The TX650 V2 is more than enough for one 6950.
A good modular PSU will cost a bit more as a consequence of having the "luxury" of removable cables. XFX sells some pretty good modular PSUs that don't cost an arm or a leg. I'd also recommend Antec except that its modular PSUs are only partially modular.
As tiraides pointed out, a decent modular PSU isn't that much more. In fact, the XFX mentioned by tiraides is only $3 more than that Corsair:
$93 - XFX P1-650X-CAH9 650W Modular PSU
Just thought I post an update with my final build.
Everything has been ordered and the last parts will be showing up in the next 2 days.
I ended up making a few changes from the original list, due to different combo deals and sales that were available.
Case: Corsair 650D
MoBo: MSI P67A-G45
CPU: Intel I5-2500k
RAM: CORSAIR Vengeance 8GB ddr3 1600
DVD: SAMSUNG SH-S243N
PSU: XFX 650X
GPU: MSI R6950 Twin Frozr III PE/OC
+ Win 7 SP1 64-bit
Total (w/ shipping&tax) $1038
The final cost was less then the initial costs I had planned for and stayed under my budget. I was able to get the 6950 as an open box, which helped allot. But then I ended up spending more for the case, getting the 650D instead of the Haf 912. I held off buying the H60 for a cooler and (for now) will be using a CM TX3 I got from a friend as a temporary part. I'm going to wait until there are some reviews of the H100 out, before I decide on that or on a different cooler (that will be able to fit with the vengeance ram I have.)
