New Build Suggestions!!! Thanks
mojosephwu
Spec:
i5 2500k
Asrock extreme4 p67
cooler master 212+ (two yate loon high speed push pull setup)
Corsair vengeance 1600 mhz 4GB(2x2gb) ram
corsair 650w tx series v2 psu( or i might get the hx series depend on the combo deal on newegg.)
cooler master 692 advanced case(if i have more money i might get the 932 or phantom case)
asus dvd rom(just the normal one for like 15 bucks)
x1 Sapphire radeon 6950 2GB(going to unlock shader)
1 Crucial m4 64GB SSD
1 Samsung spinpoint f3 1TB Harddrive.
i have monitor mouse and keyboard ready.
My budget is around 1100 without tax and shipping.(based on newegg.com price/combo deals)
Feel free to give any suggestion on changes
can a twin frozer II 6950 2GB unlock shader? is it good?
It would help if you answered the stickied "ANSWER THESE QUESTIONS FIRST!" so that we can help you better.
gaming/web browsing
budget is around 1100 without tax and ship with newegg.com's price
3) Where do you live?
i live in California
4) What exact parts do you need for that budget? CPU, RAM, case, etc. The word
"Everything" is not a valid answer. Please list out all the parts you'll need.
I need
CPU,mobo,PSU,GPU,SSD,HDD,chasis,ram,heatsink,dvd rom.
i'm building an entire new system.
6) Will you be overclocking?
yes i will be overclocking my 2500k to around 4.5+GHZ
i have a 21.5" monitor LED 1080p
i'm planning to get it in may this year.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
mobo needs to have raid, crossfire, usb 3.0, sata 6GB/s, onboard sound, trim support.
Yes i already have a legit window 7 OS 64bit
The sandy bridge does not care about your ram,Just get some good quallity 1333 ram to save money. you will be within your budget and it is a good build.
Try to buy as much of your parts as possible from Amazon.com since they don't charge tax to CA residents. Not to mention they usually have free shipping on certain in-demand parts. Not to mention that some of those parts are cheaper on Amazon.com (the HSF and hard drive). In fact, the tax savings negate some of the Newegg combo deals actually.
Your CPU, HSF, HDD, PSU, case, and SSD choices are fine. Again get those from Amazon.com
Motherboard wise, is the two year warranty an issue for you? Note that similar priced motherboards have a three year warranty.
RAM wise, I don't recommend that Corsair set at all for two reasons:
1) It's a 2x2GB set which limits your future RAM upgrades to 12GB max.
2) DDR3 1600 offers little to no real world performance increase over DDR3 1333 RAM. As such, unless you love synthetic benchmarks all day long, you won't notice a difference between that Corsair set and this Patriot RAM:
$39 - Patriot PSD34G13332 2GB DDR3 1333 RAM
DVD rom wise: $15 is way too much for a DVD rom drive considering that a regular DVD burner costs $20. So either A) find a DVD rom drive for $10 or B) get a DVD burner. Either route will be a better use of your money.
GPU wise: The Twin Frozer probably can't unlock since it's not a reference design AFAIK. As for the Sapphire, I have to ask you this: What matters more? The ability to unlock or a longer warranty and better customer support? I ask because Sapphire is definitely lacking in the latter.
The vengeance currently has 30 bucks MIR, so it's 30 bucks after rebate for 1600mhz 4GB ram
Yeah I don't factor in rebates as they're not guaranteed discounts. I only factor in rebates when that rebate check is in my hands.
