Looking for some advice or recommendations on new build
gaming/ web browsing
$1000
3) Where do you live?
NJ
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Everything
I have a 22" HP monitor, keyboard, mouse and speakers. I have an extra 320gb sata hd too
6) Will you be overclocking?
Right now no...but may in the future
7) What size monitor do you have or plan to have?
22" HP f2105
within the next few weeks
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Lots of SATA ports...
Here is what I was thinking of getting
CPU/ Motherboard - ASUS P5E LGA 775 Intel X38 ATX Intel Motherboard $199 http://www.newegg.com/Product/Product.aspx?Item=N82E16813131219
VGA - BFG Tech BFGE98512GTXOCE GeForce 9800 GTX 512MB 256-bit GDDR3 $149 http://www.newegg.com/Product/Product.aspx?Item=N82E16814143137
RAM - G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) $60 http://www.newegg.com/Product/Product.aspx?Item=N82E16820231166
PSU - CORSAIR CMPSU-650TX 650W ATX12V / EPS12V $95
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
HDD - Seagate Barracuda 7200.11 ST3500320AS 500GB 7200 RPM 32MB Cache $60 http://www.newegg.com/Product/Product.aspx?Item=N82E16822148288
DVD Burner - LITE-ON Black SATA 20X DVD±R DVD Burner $24 http://www.newegg.com/Product/Product.aspx?Item=N82E16827106263
Total is $587
I already have Vista 64...I haven't decided on a case. Suggestions, recommendations or advice very much appreciated
$1000
NJ
Everything
22" HP f2105
Total is $587
