Im trying to help my friend solve a issue. He just put together a new system.
anyway specs as follows
Aerocool ExtremEngine 3T case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811196021
Amd 5000+ x2 black zeromtherm 120cm cooler
asus M2N32SLI Deluxe
bfg 650watt sli psu
2 1 gig kingston 5300 ddr2
80 gb sata hd
evga 7800gt
sata dvdrom
win xp
we had a issue on boot up, trying to solve what it is now. first it would beep once fans spin 1 second or so and nothing. remove the video card it would run fine. so we thought maybe try another video card, we did same result. i had another friend look at it, he moved the ram and it booted this time, but he unplugged the case fans. however we thought it was the ram. plug the fans in, and it wont boot. unplug them and it boots, i think both case fans are 2pins in a 4 pin molex housing. From what it looks the fan control knobs and the case fan are the only issue. If the are plugged in no boot,Im trying to figure it out, I could try another psu, but i dont see how power can be the issue with the minimum hardware in the machine, any idea on what to doublecheck or try would be great. thanks in advance.
bfg 650watt sli psu
80 gb sata hd
evga 7800gt
sata dvdrom
win xp
