New Build Problem.
Carter54
I just built a NEw PC specs are in my sig and once in a while when I hit the Power button I get a loud constant beep from the MB speaker and then nothing. I reset a couple times or wait 5 then try again and it boots right up anyone seen this before? Does anyone have a good link to BIOS beep codes I have been trying to find something on this but no luck so far.
Does it do it only when the computer is cold. I mean if you use it for a while then quiclky shut it down and power it back up do it also do the beep ?
I am thinking the fan is not immedately starting up and you are getting a fan warning or a cpu temp alarm. not quite sure which. I dont have that board so I dont know what you have in the bios for fan/temp settings. Try turning EIST off if you have it.
Is that the zalman with the PWM fan (4 pin) or the 3 pin and if the 3 pin where do you have it plugged in at ?
all I can think of for now lol an asus guy will probally come by and nail it.
Ok questions one at a time
Fan speed is set to 600 RPM in BIOS but it does not even get to POST.
The Zallman is the 3 pin and I have it in the CPU fan plug with the fanmate controller plugged in but the fan is spinning.
It has done it both hot and cold some time it wont post and I have to go in and reseat all of the cables and the RAM. Very Annoying! I was originally thinking the ram but now its doing it very random and reseating the RAM doesnt always fix it.
In your bios you have an option to ignore your cpu fan. it is under Hardware monitor, try setting it to ignore and see what happans. I had an old P5ND2 sli and the it hated the Zalman fan controller.
Also are you getting the same results at stock settings as well when your overclocked.
