New build! Please critique
rentay
Gaming, Photoshop, Web Browsing
$2500 - $3000 AUD
Australia
Motherboard, PSU, CPU, Graphics Cards, Ram, CPU cooler, SSD
Silverstone TJ-07 and Razor Mouse/Keyboard, WD hdd
6) Will you be overclocking?
Somewhat
Acer 24" Maximum resolution: 1920x1200
In the next 1-2 weeks!
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
USB 3.0, SATA 6gb/s, SLi
Yes, Windows 7 Ultimate 64bit
Hi all!
Below is my computer build! If you could critique it, I would be much appreciated!
CPU
Intel Core i7-2600K
Motherboard
Asus Maximus IV Extreme
Memory
Corsair Vengeance CMZ8GX3M2A1600C8 8GB (2x4GB) DDR3
Graphics
EVGA GeForce GTX580 Supeclocked 1.5gb (or should I opt for 3gb?)
Storage
OCZ Vertex 3 120gb
Powersupply
Silverstone 850w modular (or should I opt for Corsair/Seasonic?)
CPU Cooling
Corsair Series Hydro H80
Thanks! :D
Only 8gb with that build? Ram so cheap now days might as well bump that up to 16gb.
Drop the vertex 3 and go with something more reliable like an intel or crucial drive.
I would go with a seasonic psu because they are generally great quality.
You could save tons of money by dropping some of those items to the part just under them, like 2500k, gtx 570, cheaper mobo but that's up too you.
Which Silverstone 850W modular PSU are you talking about?
I'd ditch that Vertex 3 for the more reliable and better supported Crucial M4 128GB SSD. As for the motherboard, judging from your answers so far, that mobo seems overkill for your needs. This mobo should meet your needs just fine:
$195 - Asus P8Z68-V Pro Intel Z68 ATX Motherboard
GPU wise, go for the 3GB version.
Unless you plan to go multi-monitor, or upgrade to a higher resolution one, you should be fine with the 1.5GB card. The 3GB ones are way overpriced, in my opinion you'd be better off with a 6970 2GB if you are worried about the VRAM.
