Sparkynutz
- Jul 31, 2007
I Have an old computer I built in 2007 running XP that is finally seeing its day and thinking of upgrading.
(Q660 cpu, abit ip35 pro mobo, 2gb memory, and Nvidia GeForce 8800gts 512mb video card)
I was planning on keeping it as a spare computer for my son, but in the end it will most likely just collect dust.
I'd like to keep it cheap as possible, but not take any shortcuts. I got a good 7 years out of this old computer and hoping to get the same out of a new one.
If you were me, would you sell it as is and put cash towards new build, or part it out and use what I can?
Web, Starcraft 2, some light video editing.
$500-800 Cheaper the better
US, Waupun, Wisconsin
Everything except monitor, mouse, keyboard, unless I part out and use some of my old computer as a base.
Power supply- http://www.newegg.com/Product/Product.aspx?Item=N82E16817139001
Cooler Master Centurion Case. I don't recall where I bought it or what model is and googling hasn't easily turned up my case.... its old but I like it and would probably be adequate yet.
I just bought a new video card to put in current computer this week to hold me over and eventually use in the new computer build
http://www.newegg.com/Product/Produ...7024&cm_re=evga_750_ti-_-14-487-024-_-Product
6) Will you be overclocking?
Doubt it. I just slightly OC my current Q6600, but I don't plan on it with this build. Atleast right away or for a couple years.
Cheapo Acer 19" widescreen 900x1400 or something. Might upgrade to 21" or something eventually. I doubt I'll go any bigger.
6 months - Year
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Firewire if I can get it yet.
Sata/ eSata not sure. I don't recall much about the hard drives from this build.
I want an SSD for windows and probably use old drives for storage if they work. If not, I'll get a usb case for them and use as portables.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
I like the idea of Windows 7 because its more like XP and I'm dreading the switch, but kinda thinking to say screw it and get newest out 8.1 or whatever. Maybe even wait till 9 comes out and build computer then.
6 months - Year
