My boss has asked me to spec out a new machine for use at work (will be employer owned). and I could really use some input from you Pros here to make sure I've done my homework
The machine will not be OC'd -Stability is a must (sorry, kind of boaring isn't it
Primary machine use: Graphics (AutoCad, MicroStation, etc) and proprietary Simulation applications involving graphics/terrain
Operating System: XP Pro (32/64bit), Linux Redhat 32/64bit, Vista 32/64bit
I've spec'd out 2 configurations AMD and Intel
I can wait for the AMD Phenoms to come out if Quads are worth it for this kind of work. It's not clear to me whether our work will benefit from Quads or if 2 cpus is more than adequate.
Thanks for any comments/suggestions
Intel Spec Configuration
1. Motherboard - ASUS P5E 775 Intel X38
http://www.newegg.com/product/product.asp?item=N82E16813131219
2. Processor - Intel Core 2 Q6600
http://www.newegg.com/product/product.asp?item=N82E16819115017
3. Memory Corsair XMS2 DDR2 800 (PC26400C5DHX) (4GB -2x2GB)
http://www.newegg.com/product/product.asp?item=N82E16820145176
4. Graphics Card GeForce 8800GT (EVGA 512-P3-N802-A1)
http://www.newegg.com/product/product.asp?item=N82E16814130303
5. Hard Drives Western Digital Raptors (150GB) (3-each)
6. Monitors 30 Samsung SyncMaster 305T (2 each)
http://www.newegg.com/product/product.asp?item=N82E16824001098
7. PS PCPower & Cooling Silencer 750 Quad
http://www.newegg.com/product/product.asp?item=N82E16817703009
8. Case Silverstone TJ09
9. UPS Belkin 1500VA 830W
AMD Spec Configuration
1. Motherboard ASUS M2N32-SLI Premium Vista Edition AM2 (590 SLI MCP)
http://www.newegg.com/product/product.asp?item=N82E16813131163
2. Processor AMD 64X2 6400+
http://www.newegg.com/product/product.asp?item=N82E16819103191
All other components are the same as for the Intel Configuration above
