So I will start off with the required questions:
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing? Predominately dev work, multiple instances of VS 2012, MS SQL, etc, with some occasional heavy gaming
2) What's your budget? Are tax and shipping included? Trying to keep it about 1200
3) Which country do you live in? If the U.S, please tell us the state and city if possible. St Petersburg FL
4) What exact parts do you need for that budget? cpu, mobo, ram, drives, video card
5) If reusing any parts, what parts will you be reusing? I just bought a SEASONIC X750
6) Will you be overclocking? Yes
7) What is the max resolution of your monitor? What size is it? 2560 x 1440 put a pre-order in on an Overlord 27 inch OC PP (not included in budget above)
8) When do you plan on building/buying the PC? Over the next couple of weeks (by Dec 1st)
9) What features do you need in a motherboard? MOBO is already picked
10) Do you already have a legit and reusable/transferable OS key/license? Win 7 and Win 8 64bit
Ok, first of all, I am building this computer as an integral part of my new desk.
Picture of desk so far for reference:
http://www.liqdfire.com/photos/desk/_DSC8238.JPG
Kind of where I am going with computer integration:
http://www.overclock.net/t/1200785/project-kapros-ikea-galant-pc-desk-mod
So these are the componets I have picked so far, I am stuck on video card, and would like input on possible performance bottlenecks on other parts. I am planning on doing a custom water cooling setup, and integrating that into the desk as well.
ASUS Maximus V FORMULA
http://www.amazon.com/Maximus-FORMU...UTF8&colid=PP24CA0D4MZG&coliid=I1PQA2J5WUT2IR
Corsair Vengeance Red 32GB (4x8GB) DDR3 1866 MHZ
http://www.amazon.com/Corsair-Venge...UTF8&colid=PP24CA0D4MZG&coliid=I2UA06H2N46365
Core i5 3570k
http://www.amazon.com/Intel-Core-i5...UTF8&colid=PP24CA0D4MZG&coliid=I2KIRICD5F09X1
Crucial mSata 256Gb SSD for main OS / will probably put in another drive for storage
http://www.amazon.com/Crucial-256GB...=UTF8&colid=PP24CA0D4MZG&coliid=IL4VUQIFMEFW0
Thanks in advance!
Core i5 3570k
Thanks in advance!
