New build, need advice.
crown7
Some gaming, light photoshop use, watching movies, all around normal pc use
$700.00 including tax/ship
Fresno, CA.
PSU, RAM, DVD-Rom/*Blu-ray player if possible*, HDD, CPU, Motherboard, Case
HD 6970 2GB, x3 24' Asus VK248H 1920x1080 monitors
6) Will you be overclocking?
If need so, yes.
7) 7) What is the max resolution of your monitor? What size is it?
1920x1080 24'
asap
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Sata 6Gb/s, hdmi, cf incase i pickup another gpu in the future
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Yes, win7 64bit
I have these monitors sitting in my closet, thought I'd use them for a basic eyefinity setup, I don't need anything to provide maximum performance. I'm fine with gaming at mid level settings if need so. Heres what I had in mind.
CPU: FX 4170 http://www.newegg.com/Product/Product.aspx?Item=N82E16819106009
Board: ASRock 990FX Extreme3 http://www.newegg.com/Product/Product.aspx?Item=N82E16813157281 (it's probably a bad board but I'd like to stay away from the blue colored boards. i'd like a dark theme build or red this time)
RAM: I read good reviews about RipJaw's plus the color scheme would match well.
edit* after hunting around I was able to find a 2500k NIB for $40 more over the 4170, would it be worth the extra dough?
i'd appreciate any input or advice here guys! thanks!
Does it have to be all black or can it have a smattering of blue or orange?
Yes, get that 2500K right now. It's worth the extra cash in every way possible.
Well, if possible I would like to keep it without any other colors but black and red as possible but I know I can't be picky on my budget. I've noticed some boards have 1 vga, 1 hdmi, and 1 displayport or dvi like the ASRock Z77 Extreme6 would I need adapters for 3 monitors with boards like that still?
Are you buying the i5-2500K from an online retailer? If so, where?
I'm purchasing the 2500k nib from a private party, budget build forced me to roam around craigslist lol
The problem is that the mobos that fit your exact color scheme requirement are all AsRock mobos. Frankly put, we generally don't recommend AsRock mobos here in General Hardware since they appear to be inconsistent when it comes to quality and HardOCP hasn't reviewed the Asrock Z77 mobos yet.
No.
Don't get stabbed!
Anyway, since you live in CA, buy as much of your parts as possible from Amazon.com since they do not charge you sales tax like Newegg does. Here's what I recommend so far:
$180 - Core i5 2500K
$160 - MSI Z77A-GD65 Intel Z77 ATX Motherboard
$47 - Corsair CMV8GX3M2A1333C9 2 x 4GB DDR3 1333 RAM
$81 - Seagate Barracuda 1TB Hard Drive
$17 - Samsung SH-222BB/BEBE SATA DVD Burner
$94 - Corsair 750TX V2 750W PSU
$100 - Antec 1100 ATX Case
$20 - Cooler Master Hyper 212 Plus HSF for LGA 1366 and LGA 1156
Total: $699 shipped.
