New build, need advice.
hitch_ic05
I've been lurking off and on now for some time ever since buying my current system off a friend who hung around here. I bought that system sometime back in 2006/2007, so I'm due for an upgrade.
I'm currently working with:
PSU - Antec New HE 430
MoBo - Gigabyte 965P-DS3
CPU - Intel Core 2 Duo E4300 @ 1.8 GHz
RAM - 2x Corsair DDR2 1Gb
Graphics - ATI Radeon x1800 series
I'd like to start from scratch and build a whole new machine. I'm also thinking of turning my current system into a file server. Anyways, here's my answers to the build questions:
Gaming (SC2, Civ5, etc), Streaming video/music, Work (Programming via remote desktop connection and locally), Web browsing, some minor photo and video editing though nothing major
$1000 - $1200, all included
3) Where do you live?
Tulsa, OK
Case, MoBo, CPU, RAM, PSU, Graphics card, HDD (preferably SSD), DVD burner
Will be reusing 2 monitors (specs below), keyboard, mouse, webcam, printer
6) Will you be overclocking?
At first no, maybe later depending on how adventurous I get
Main monitor: 22" Acer w/ max res of 1680x1050
Second monitor: 20" Acer w/ max res of 1600x900
I really would like to jump in a build it ASAP. Am also looking for advice on whether or not to wait for Sandy Bridge.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
Decent on board sound, 1 Gb ethernet
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Win 7 Pro 64-bit
After reading some other threads and doing some browsing around I've come up with a preliminary build. What do you think:
$60 - Cooler Master HAF 912 RC-912-KKN1 ATx case
$365 - Intel Core i5-750 Lynnfield 2.66GHz & ASUS P7P55D-E Pro LGA combo deal
$110 - Antec TruePower New TP-750 750W PSU
$100 - G.SKILL Ripjaws Series 8GB (2 x 4GB) DDR3 SDRAM
$200 - EVGA 01G-P3-1370-TR GeForce GTX 460 (Fermi) 1GB 256-bit GDDR5
$135 - Crucial RealSSD c300 64GB SATA III
$17 - Sony Optiarc CD/DVD Burner
$987 + tax and shipping
I was also thinking of adding a 1TB HDD for more storage, so I could use some recommendations there.
Thanks!
do you need an ssd?
personally I'd get a cheap 1tb hdd, and a gtx 470
looks like a solid build though
I recommend this 1TB drive for storage:
$60 - Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive
As for waiting for Sandy Bridge, I say wait. It's only three weeks away. I think you can hold onto your old rig for now.
Afaict sandy bridge will be bringing us a double whammy of higher clockspeeds at each pricepoint and higher IPC. Further if you buy LGA1156 now you can basically forget about any significant CPU upgrades down the line whereas LGA1155 as the start of a new platform should have more upgrade options.
On the downside it appears the only way to overclock sandy bridge will be to buy the unlocked K series models.
