New Build - Need a couple suggestions
Jynio
Hi,
UPDATE: Just updated all the specs. I'm planning on placing the order tomorrow since there are a few sales at ncix. Checkout the list below, and let me know if you have any suggestions. Thanks in advance.
LIAN-LI PC-A77B Black Aluminum ATX Full Tower Case
http://www.ncix.com/products/index.php?sku=31065
$300.00
ASUS P5Q Pro
http://www.ncix.com/products/index.php?sku=30418&promoid=1066
$139.99
EVGA E-GEFORCE GTX 260 Superclocked 602MHZ 896MB 2.052GHZ
http://www.ncix.com/products/index.php?sku=30962
$299.00
Corsair 620HX
http://www.ncix.com/products/index.php?sku=19831
$159.00
Intel Core 2 Quad Q9450
http://www.ncix.com/products/index.php?sku=29316&promoid=1066
$319.00
Thermalright ULTRA-120 Extreme
http://www.ncix.com/products/index.php?sku=23531
$65.00
(2) Western Digital Caviar SE16 640GB
http://www.ncix.com/products/index.php?sku=30004&promoid=1066
$78.99 x 2 = $157.98
Scythe S-FLEX SFF21E (TRUE fan)
http://www.ncix.com/products/index.php?sku=17747&promoid=1066
$10.99
(4) Scythe S-FLEX SFF21D (Case fans)
http://www.ncix.com/products/index.php?sku=17746
$14.99 x 4 = $59.96
(2) G.SKILL F2-8000CL5D-4GBPQ PC2-8000 4GB 2X2GB DDR2-1000
http://www.ncix.com/products/index.php?sku=26456&promoid=1066
$94.99 x 2 = $189.98
Microsoft Windows Vista Home Premium Edition 64BIT DVD OEM
http://www.ncix.com/products/index.php?sku=22438
$132.00
Arctic Silver 5 (3.5g)
http://www.ncix.com/products/index.php?sku=10715
$12.45
Razer Goliathus Standard - Control Mouse Pad (It's been 10yrs, it's time for a new pad)
http://www.ncix.com/products/index.php?sku=31264
$20.00
Total - ~$1,870 + tax = Roughly $2150.00 CAD
Mail in rebates not included. Might save an extra $100 or so.
Cheers.
1. I'd say get a different case, but if you really like Lian-Li cases, then I can't help you there (I live in the US). Size-wise, one of the Cooler Master Stacker or Cosmos series cases would be a good alternative. (Whether or not they look good, though, is up to you.)
2. The Xigmatek HDT-S1283 is a good choice. The Crossbow mounting kit also makes things easier for you in the long run.
3. If you're trying to keep things quiet, the VelociRaptor is not the way to go. I would suggest picking up either the Western Digital Caviar SE16 640GB HDD or the Samsung SpinPoint F1 750GB HDD. Instead of the VelociRaptor and a storage HDD, I suggest just getting two of the same HDD.
4. Go with what gives you what you need -- either the Media Center features of Vista Home Premium or the backup/networking features of Vista Business.
If you plan on gaming with your machine (in addition to the tasks you told us about earlier), you may want to get the HD4870 instead. If you have a monitor under 22 inches, however, I recommend the HD4850 (or the 9800GTX+ if you must stick with NVIDIA).
Nice rig! +1 on the P5Q Pro. The Q9450 is EOL, look at the Q9550. Pricing is now a push. The WD 640 suggestion is a good one, but the WD 320 is quieter, but less performance. Suggest you pick your memory from the Asus QVL. The G.Skill in my sig is on the QVL.
Though the Q9450 is EOL, it's still widely available at this moment. It could also reach the same approximate OC thresholds as the Q9550, so the OP doesn't have to spend so much for performance.
The WD3200AAKS may be quieter than the WD6400AAKS, but noise is very subjective. Regardless the WD6400AAKS and the F1 750GB are both much quieter and have a better price/GB ratio than the VelociRaptor.
The problem with most motherboards' QVLs (qualified vendors list) is that they can't account for every type/model of memory available. As long as the memory can follow the JEDEC specifications (for example, 5-5-5-18 @ 1.5V for DDR2 800), the memory will run on most motherboards fine. However, I do agree that G.Skill is a good choice among many others.
Thanks for the feedback. I was reading at Silentpc that the VelociRaptor drive was one of the quietest when the heatsink was removed. Maybe I'll be better off picking up a couple 750GB F1 drives to save some cash though. Are the Samsungs reliable?
I was looking into the Lian-Li PC-8 case. Would I run into any problems with a mid tower? The Cooler Master Stacker and Cosmos both look nice, but aren't really my style.
Should I be picking up some G.Skill DDR2 800 or 1000? I'm starting to consider running 8GB, just because I'm usually running some large Photoshop files, while multitasking in After Effects, and Maya at the same time.
Would the Corsair 520HX provide enough power for the rig? The 620HX is roughly 40$ extra, although I doubt it's necessary. I could put that cash into a Q9550 instead of the Q9450 :)
Thanks again.
While I'm pretty sure the 520HX might work, I'd go with the 620HX just to be sure if you are set on Corsair. I have the 520HX myself, and it's a great little PSU; that said, I'm not sure it could power such a rig at full load.
RAM-wise, I'd be looking for the DDR1000. Case-wise, its up to you. The PC-8 looks like a nice case, but I might suggest something a little bigger just for ease of working in.
The 520HX is more than enough power for your rig. With that said, don't spend that $40 towards the Q9550 since it's a waste of money. All you're getting for that extra $40 over the Q9450 is an extra .5 multiplier and 133Mhz speed. Not worth it IMO. So spend that extra money on the 620HX. Better use of your money than a CPU move.
RAM wise, definitely G.Skill DDR2 1000 RAM.
The Samsung F1 drives are reliable, and Samsung HDDs are compartively quieter than other brands. However, the Western Digital 640GB drives perform faster/better.
If you're only using two hard drives, you shouldn't have any trouble with the Lian Li PC-8 case. It has a HDD cage that supports three hard drives, plus you have two 3.5 inch slots and four 5.25 inch slots. (I don't know how quiet the stock fans are, so you may want to consider getting some quieter fans.)
As for RAM, stick with DDR2 800 if you're planning on running everything at stock speeds. If you're overclocking, go with DDR2 1000 or DDR2 1066 (they'll enable you to reach the same thresholds, but DDR2 1000 is normally cheaper). If you want it, go ahead and grab 8GB of RAM... but having all four RAM slots filled will put more stress on the motherboard's MCH and limit how far you could overclock the processor.
That's a monster system to have a lowly GTX260 for graphics.
Grab an e8600 core 2 and use the money you saved for a GTX 280. Your overall gaming performance is going to be much better.
:rolleyes:
... Basically I work from my computer 24/7, using mostly Photoshop, Flash, After Effects, and Maya. ...
... he's not gaming 24/7, so he'd be better off with the quad for 3D rendering.
Yep, I'll be using it for work 90% of the time. Definitely going quad core to help cut down week/month long renders. I just need a decent video card for the occasional day when I'm looking to kill time playing some games. My biggest concern right now is the case. Hmm, maybe the Antec P182, although it looks a little small and cheap.
Any last minute suggestions before I place the order this afternoon? Do you think I'll need any extension cables for that full tower?
