chinspecial
- Sep 25, 2007
So I'm building a new rig and it's on a very tight budget. Working basically around the intel retail edge pack. In case you're not sure, the mobo is the Intel® Desktop Board DG33TL Media Series. I was wondering if I should just hang onto that board for a while until I can afford the upgrade. I don't plan on doing any OC'ing, at least atm. Also it seems to have all my basic needs. So should I keep it, or should I try to make some money off of it and Vista (don't need os) and try to buy a dif one?
