It's been a few years since I built my last PC. I'm pricing out a new build that will be used mainly for Photoshop CS6, Lightroom 4, and mild gaming. I'm currently using a 21.5" iMac with 3.06ghz c2d and I find it struggling to process my Nikon D800's 40-50mb files.
Let me know what you guys think. I appreciate your advice.
Mainly Photoshop CS6, Lightroom 4, web browsing, and mild gaming. Must be able to process 40-50mb files quickly.
2) What's your budget? Are tax and shipping included?I'm looking to spend around $800-1000 inclusive.
3) Which country do you live in? If the U.S, please tell us the state and city if possible. Pittsburgh, PA, USA
4) What exact parts do you need for that budget? CPU, RAM, case, etc. The word "Everything" is not a valid answer. Please list out all the parts you'll need. CPU
GPU
RAM
Mobo
Harddrive
Power supply
CPU cooler
Optical drive
OS
Case
Monitor
5) If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. List make and model.GPU
RAM
Mobo
Harddrive
Power supply
CPU cooler
Optical drive
OS
Case
Monitor
NONE
6) Will you be overclocking?Mild overclock.
7) What is the max resolution of your monitor? What size is it?Haven't purchased yet.
8) When do you plan on building/buying the PC?Within next few weeks.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.No special requirements.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit?No.
