Heavy gaming, movies, web browsing, graphics editing
1500-1800 but flexible upwards for any must haves
3) Where do you live?
New York, NY
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Almost a complete build.
Reusing DVD drive and extra hard drives
6) Will you be overclocking?
I may expirement some, but level of expertise in OC is low.
7) What size monitor do you have or plan to have?
40" sony lcd xbr3
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
I'd like the ability to SLI/Crossfire in the future.
Current build:
Intel Core i7 920 Nehalem 2.66GHz LGA 1366 130W - $299.99
EVGA 132-BL-E758-A1 LGA 1366 Intel X58 ATX Intel Motherboard - $299.99
CORSAIR XMS3 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) $229.00
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case - $109.99
WD VelociRaptor WD3000GLFS 300GB 10000 RPM SATA 3.0Gb/s - $229.99
PSU - Antec TPQ-850 850W ATX12V / EPS12V - $149.99
EVGA 01G-P3-1280-AR GeForce GTX 280 1GB 512-bit GDDR3 - $344.99
Total: $1,663.94
Any suggestions / improvements would be appreciated. What do you think of the PSU? I guess the goals here are to have the best system I can for my price range. I'd like to be able to play Crysis on max settings and have a system I can build on for the next couple years. This is also my first build so ease of setup is also important. Thanks.
New York, NY
40" sony lcd xbr3
ASAP
Current build:
Total: $1,663.94
