digitalgunfire
- Aug 26, 2008
My current ring:
Q6600 @ 3.2GHz
5850
4GB RAM
Antec P182 case, 650W Corsair supply, 1x500GB drive, 1x400GB drive
I have a friend who I can get $400-500 for the PC from.
I'm looking to build a new system and I'm just looking for some input on whether it's a worthwhile upgrade. I'll be playing BF3, Skyrim, Rage, Guild Wars 2, also do a decent amount of web development. I figure it will be but I want it to be a significant upgrade otherwise I'll wait until next year.
Here's the answers to the questions + the build.
Mostly gaming, some programming/web design
Hoping to stay around $1000 but should be able to sell my old rig for $400 or so
US, Wisconsin
CPU, ram, video card, case, power supply, HD, motherboard
N/A
6) Will you be overclocking?
Yep, hope to take the CPU to 4+GHz, doubt I'll touch the GPUs.
24" 1920x1200
By November
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
Crossfire support would be nice, don't care about firewire, must have USB 3 and SATA6
Yep, 64bit Win7
Here is my build, please note the dual 6870s, I'm interested in input there.. they seem like the best option right now. I want to be able to run Skyrim, BF3 etc at max at 1920x1200. I understand we don't know the exact specs required yet but I'd like to make a good guess at requirements.
Q6600 @ 3.2GHz
5850
4GB RAM
US, Wisconsin
N/A
24" 1920x1200
By November
Yep, 64bit Win7
- Corsair Carbide Series 400R Graphite grey and black Steel / Plastic ATX Mid Tower Gaming Case
- ASUS P8P67 (REV 3.1) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
- XFX HD-687A-ZHFC Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card x2
- CORSAIR Enthusiast Series TX750 V2 750W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power ...
- Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
- G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL8D-8GBXM
- Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
- COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible Intel ...
