New build in Antec 900
Are you set on Nvidia? $200 or even $175 is a way too much to pay for the performance of the GTX+ and I'd rather have an Intel chipset over the 750i if you're just going with one graphics card. The 4870 512MB just had a price drop to $149.99 so we'll probably see non-rebate prices hitting that mark within the next couple of weeks so that's the way I'd go for graphics. For mobo, Asus P5Q Pro or Gigabyte EP45-UD3R would be my choice. I'd also swap out that Corsair ram for the Geil Black Dragon set Newegg has for $38.99, it overclocks much better and looks better as well imo.
Is this build supposed to be a gaming build? On a monitor with a resolution of at least 1680x1050? Do you plan on overclocking this rig as well?
While there's plenty of ways that you could save money on this build, you need to give us more details so we have some ideas to base our recommendations on. Read the sticky labeled "Looking for Build Help?" and answer the questions that are listed there.
(And skyline889, depending on where you live, the G.Skill DDR2 800 kit with free shipping is oftentimes cheaper than the Geil Black Dragon kit.)
yea this is a gaming build. no video editing or any stuff like that. i currently have a NEC Multisync LCD1935NXM ( 1,280 x 1,024 resolution, 0.294 mm dot pitch. 450:1 contrast ratio, 250-nit brightness, 16 ms response .Analog and digital DVI-D inputs). its 4 yrs old just like my shuttle that just died. im guessing im gonna need a new monitor?
1) What will you be doing with this PC?........Gaming
2) What's your budget? Are tax and shipping included?........$650ish
3) Where do you live?.....New York
4) What exact parts do you need for that budget?.......CPU, RAM, Case, Mobo, Video Card, PSU, Monitor??? look below
5) If reusing any parts, what parts will you be reusing?.........none
6) Will you be overclocking?...........would like to im scared tho :x
7) What size monitor do you have and/or plan to have?..........NEC Multisync LCD1935NXM ( 1,280 x 1,024 resolution, 0.294 mm dot pitch. 450:1 contrast ratio, 250-nit brightness, 16 ms response .Analog and digital DVI-D inputs)
8) When do you plan on building/buying the PC?......Newegg
9) What features do you need in a motherboard?.....would like SLI to add another video card in down the road
10) Do you already have a legit and reusable/transferable OS key/license?.......yes
You don't need to be spending all of that money on those particular components.
More often than not, you could find the case cheaper at Provantage (even when you factor in shipping). If you're not set on the Nine Hundred, you could also consider the similar yet cheaper Three Hundred case. (However, you'll have to purchase the front-mounted fans separately... I recommend Yate Loon D12SL-12 fans.)
You also don't need a motherboard with all of the features for the 750i -- or rather, its main feature, the dual-card SLI support. Hell, with your resolution, you don't even need the GTX 260. The Gigabyte EP43-UD3L is a cheap, no-frills board with six SATA ports and PCI Express 2.0 support... which is really all that you need for a simple gaming rig. Though it's a bit overkill for your current monitor, the HD4850 would enable you to max out most of the games that you play, and it offers decent frame rates at resolutions up to 1680x1050 (should you decide to get a new monitor in the near future). But so there's no confusion, you don't have to replace the monitor if it still works fine for your needs. And, again, you don't need a GTX 260 for your monitor, let alone two (in SLI mode).
Though the Corsair TX650 is an excellent power supply, you don't need that much power for your system. To save costs, go with a cheaper power supply like the BFG Tech LS-550. But stick with your choice in the Corsair XMS2 RAM. Though I'm not fond of mail-in rebates myself, the free shipping makes it just as good of a choice as the G.Skill kit, not to mention a bit cheaper than the Geil Golden Dragon set.
ok im gonna be upgrading along the way if i need to. im gonna stay with the evga setup probably unless there is another good combo for the money
Why bother even asking for advice? You read all what Tiraides said and just ignored all of it.
Tiraides just provided you with another mobo choice. I agree with Tiraides: SLI is TOTALLY overkill for your resolution. Considering that the only mobo feature you requested was SLI and that isn't even needed, the UD3L mobo that Tiraides is the far better choice for you.
Video card wise, again Tiraides is right: the $150 HD4850 is MORE than enough for that low of a res. With that said, the HD4870 512MB, faster than either the HD4850 and 9800GTX+, can be had just a bit more than the HD4850 and cheaper than the 9800GTX+:
Sapphire 100259L Radeon HD 4870 512MB PCI-E Video Card - $165
So the UD3L + HD4870 512MB would outperform your current setup yet would be significantly cheaper.
Oh and in question 8, I asked WHEN , not WHERE you were buying.
Sorry, I seem to have forgotten my obligatory, "I agree with tiraides." post. Consider this it. ;)
people have said on other forums its good to stick with the same brand for mobo and video card so that was my logic there. is my current monitor gonna be a bottleneck on performance?
Well that logic is bad. There isn't any real hard benefit to keeping the same brand for the mobo and video card. No performance difference, no stability difference, no overclocking difference. Nothing, nada.
And no your monitor will not be a bottleneck.
The antec 900 has "okay" wire management. If you get anything like a 260gtx or 280gtx I'd recommend you to make sure you have good wire management because it's a very tight fit.
ok so i dont need a monitor that will save some money and i am definitely gonna go with a cheaper board like you said if for most games i wouldnt be taking advantage of SLI. my shuttle that just died was an AMD 64 3700+. 1 gig pc3200. BFG 7800GT in a shuttle and i would get 125fps constant most times so whatever i get should be a drastic improvement
You still haven't answered question 8 correctly.
And I recommend against relying solely on NewEgg for all of your parts. Some of the deals that I've found for you came from other sites.
