new build help
supernova73
gaming, photoshop and light video editing
~$1000
3) Where do you live?
michigan
case,cpu,memory, mobo, hd's, possibly aftermarket cpu cooler, vid card,cd/dvd burner
reusing corsair hx620 psu
6) Will you be overclocking?
mildly
currently have 21.5 inch widescreen will probaly upgrade to 24 at some point
around beginning of feb
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
usb 3.0 would be nice but no nessecary, no need for sli/xfire
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
no win 7 64 bit need to be included in the price
I am thinking along the lines of a Haf912 case. I would like the processor to be a 6core amd so any advice after that would be great! Also have a gtx 260(200 core) but would like to upgrade that . I have a saved wishlist on newegg but i can't seem to figure out how to link it here even after i made it public.
Considering that you're planning on building around February, you're better off going with the Intel Core i5 2500K when it gets released for $215. Despite the lack of two cores, the Core i5 2500K still beats or is close to many of AMD's six-core CPUs even in heavily multi-threaded applications. Your budget should be able to fit a Core i5 2500K, even with the addition of the cost of OS.
In addition, since you're plnnaing on building in February, please come back and bump up this thread then. A lot of the builds we do here involve Neweg combo deals that either shaves off a lot of cash or allows for faster/better parts for the same price. Unfortunately those expire at the end of the month. So if you want the most to update prices/deals/selection, you're better off posting/bumping again in February if February is the earliest that you can build a PC.
In the Wishlist page, just copy the link of the wish list and paste it.
Yeah that link didn't work.
Dude, just copy and paste the names of the parts you chose.
Do you actually need all of the features of Windows 7 Pro?
Also, with the exception of the CPU, mobo and possibly OS, that setup looks fine.
The biggest feature from the pro i would like to have is the xp mode for some of those pesky programs that don't like win 7 for some reason. Not sure if my 3dsmax is win 7 compatible, if it isn't I realy can't afford to replace it.
You really should do some research as to whether or not the programs you're using will work in Windows 7 just fine. A good majority of the time, people don't use the XP mode of Windows 7.
I would suggest taking the 2500k and adding a SSD in there.
Or atleast getting a SSD at some point. You will see a much higher gain in performance with one over a slightly better CPU.
I had a very similar budget of 1200, and ended up spending $1,152.55.
The only real difference I came out with is I got a SSD, and a better GPU, while taking the slightly weaker 2500k.
But I also didnt have to buy a PSU.
http://hardforum.com/showthread.php?t=1575740
