New Build Help
Answer the questions listed in the "Asking for Build Help?" sticky so we can fine-tune our recommendations. Additionally, please answer the following questions:
- What's the most resource-intensive task or program you'll be using this computer for?
- (Assuming this is for gaming) Which games are you playing? At what level of visual quality?
Here are some cheap yet good options for the following....
Case: Cooler Master Elite 310
PSU: Seasonic S12II 520 Bronze
Optical Drive: LG GH24NS50
Video Card: Please answer all of the questions first. (Your answers may also impact the PSU selection.)
I thin before ordering the combo you should of waited & asked the questions in the sticky first.
Also, any chance you can cancel that order? It's really a bad buy for the money considering that you can get the following for not that much more:
$151 - AMD Phenom II X2 555 Black Edition + ASUS M4A785TD-M EVO AM3 AMD 785G HDMI Micro ATX AMD Motherboard Combo
$60 - G.Skill F3-10600CL9D-4GBNT 2 x 2GB DDR3 1333 RAM
$70 - Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive
$281 plus tax and shipping
Key notes:
- Bettter overclocking motherboard
- Cheaper and therefore easier to upgrade DDR3 RAM
- Significantly faster hard drive
- There's a promo code "EMCZYNW52" that'll knock off $15 off that Samsung drive.
So all in all, that combo deal you bought was a really really bad buy for the money
i know i made a mistake
i already bought the combo... :(
Photoshop and light gaming
Left 4 Dead 2, Dead Rising 2 that's about it
If you just bought it today or if it hasn't shipped yet, just cancel the order.
And again, please answer the stickied questions. There's at least 4 questions you haven't answered yet from there
Key notes:
nope too late it already already shipped. last time i listen to my friends :mad:
maybei should return this?...
Meh up to you if those notes that I mention is worth the hassle of returning the parts.
Here's the questions that you missed:
6) Will you be overclocking?
It would be too late at this point (at least not without being hit by a 15 percent restocking fee, which would get deducted from the amount that you get credited or refunded).
What that means is that of the $278.50 that you paid for that combo, you would be getting back only $236.72.
If you talk to Newegg customer service before hand and tell them that you're gonna buy other parts from Newegg, they usually waive the restocking fee
Yes, this would require a telephone call.
i'll just build this now and then ask for Upgrade options later on
right now i spent 278.50 and i'll probably spend another 200 for a case, PSU and a DVD/ Drive
No
i plan to use to HDMI Output on the Asus Mobo
ASAP as soon as i get the rest of the part
meh i don't like doing the phone return call
Probably won't be that many cost-effective ones for that setup.
Anyway, setup:
$22 - LG iHAS124-04 DVD Burner
$80 - eVGA 01G-P3-1430-LR GeForce GT 430 1GB PCI-E Video Card
$50 - Antec NEO ECO 400C 400W PSU
$40 - Cooler Master Elite 430 RC-430-KWN1 ATX Case
Total: $192 plus tax and shipping
If you're using Adobe CS5, make sure you do this hack in order to use the above GPU for GPU acceleration:
http://hardforum.com/showthread.php?t=1532552
Anyway, setup:
i'm sticking with CS4 for now
thanks for the help guys (even though i made a mistake and not asking here first)
its ok if you even get extra cash pick up a f3 500gb spinpoint or a 1tb f3 spinpoint and ditch the one that you got in your Combo. the Samsung spinpoints are very fast drives.
