So I'm building a new budget system for my girlfriend and we both wanted a new desktop so because we both wanted a new system I had to make it a good one on a budget.
Anyway, I have not built/OC'ed a machine in years and thought I needed a little refresher. I had an account here before and it was a huge help so I thought id come back for some advice.
Here are the specs of the new system:
BIOSTAR TFORCE TA790GX
AMD Phenom 9600 Agena 2.3GHz Socket AM2+
2x SAPPHIRE 100245L Radeon HD 4850 512MB (going to run X-Fire)
2x SAMSUNG Spinpoint F1 HD753LJ 750GB 7200 RPM (going to run Raid 0)
2x WINTEC AMPX 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (4 Gb Memory toal)
SeaSonic M12II SS-430GM 430W ATX12V 2.2 /EPS12V 2.91 (Modular)
LIAN LI Lancool PC-K7B Aluminum/ SECC ATX Mid Tower Computer Case
LITE-ON 20X DVD±R DVD Burner
Now I have been researching the Biostar TA790GX and I know with the Phenom you can get the memory to run at 1066 (people say it usually runs 800 out of the box) How would I go about bumping the memory up to the 1066 and get the timings up to 5-5-5-15 as the memory is rated at that speed and timing
Also what do you think would be a safe OC on that processor I was thinking maybe pushing it up to about 2.7 GHz shouldn't be much of an issue. Anyone with experience what do you think would be the best setting to achieve this without taxing the processor to much
I know I might need aftermarket cooling for the processor and also that the FET's will probably need a heatsink
Any thoughts on my setup or how my goals will be best achieved would be a great help.
Thanks a lot!
Thanks a lot!
