imgneevrythng
- Jun 5, 2008
sorry for posting a new thread with out doing a lot of research on my own but im really out of touch with technology with school + work eatting up most of my life over the past 4 months. i want to build a new pc in the next month or two...ill answer some questions about my build:
-- What your budget is: ideally ~$600. thats WITHOUT a monitor. the monitor will be paid for as a gift.
-- Which parts you need within that budget: everything except the monitor
-- What the system is going to be used for: mild gaming such as L4D, CS...but mostly school work such as 3d modeling/rendering programs like SolidWorks and graphics software like Photoshop
-- Which components you are considering getting (list out your components with model numbers/names along with links to the stores you're getting them from): AMD or Intel...nVidia or ATi. i dont really care as long as it works and works well
like i said...ideal price is around $600. im willing to go to $700 if need be, but really want to stay at $600. i figure having the monitor as a gift should help lower the cost.
i also need suggestions on a good monitor >.< ideally >19 inches
