Primarily gaming @ 1920x1080 and photoshop.
No firm budget, just don't want to waste money. Rough estimate about $1500? Would prefer to minimize tax, but consider it included.
3) Where do you live?
California
Case, CPU, PSU, RAM, video card, mobo
Nada, pretty much building from scratch.
6) Will you be overclocking?
Minor overclocking at most.
Samsung 2333SW, 23 inches.
Within the next 1-2 months.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
All of the above! xfire/SLI support is prefered along with SATA 6Gb/s and USB 3.0
Yes, Win7 64bit.
So I'm pretty much starting from scratch as I've been using an older Sager D901C for the last few years. Long story short the 8800GTX in that thing died and I don't need the mobility anymore so I'm back to desktops.
I'll probably be buying a majority of my items from Amazon to try to circumvent taxes as much as possible. Components I'm currently looking at are as follows:
Case: Cooler-Master Haf X ($189). Size is not an issue so I'd like to have a giant case for better airflow and to make it easier to work on in the future.
CPU: i7 2600k ($315). I'm up in the air between getting the 2600k now or waiting to see what Bulldozer is going to offer. Opinions would be appreciated here
Mobo: P8P67 Deluxe ($250) if I go for the i7 build, and something similar if I went AMD.
Video card: Up in the air - Sapphire 2GB 6970 ($400) or EVGA GTX 580 1.5GB ($500). Would prefer to have one of these cards as opposed to xfire 6950s so I can have the option to add another card in the future. Any opinions on Sapphire/EVGA vs. other competitors? For the 580, is the 3GB worth the extra money?
PSU: Corsair 850TX v2 ($125). Opinions on PSUs are welcome.
RAM: 8GB Corsair Dominator or Vengeance ($100).
Additional cooling: I'm also thinking about picking up a Hydro H70 ($100) to get some easy water cooling. Any thoughts about this particular unit?
For the other stuff, I have a Crucial C300 128GB on the way as well as a LG blu-ray burner so I'm not considering that as part of the budget any longer.
Using rough Amazon pricing, it comes out to $1,579 with the 580 or a $1,479 with the 6970.
Thanks in advance!
California
Yes, Win7 64bit.
Thanks in advance!
