New build help needed
merc141
Gaming, photoshop, web browsing, programming...
I would like to keep it less than $1500 or so w/o tax and shipping, but this is negotiable
3) Where do you live?
Southern California - inland empire
Case, cpu, psu, ram, motherboard
I have an ASUS 1920x1080 monitor, EVGA gtx460 graphics card, liteon dvd drive, samsung (i think) hard drive
6) Will you be overclocking?
nope
i think its 22" or 24"
within a week or so
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
6Gb SATA would be nice, USB 3 would be cool too. I really just need a MOBO that is rock solid, something that will definitely last a while.
I have win7 64 bit already.
The build so far:
Intel Core i7-2600K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070
Corsair Obsidian 650D
http://www.amazon.com/Corsair-Obsid...1?ie=UTF8&s=electronics&qid=1304478823&sr=8-1
...the 650D on newegg (where I wanted to order everything from) is deactivated. Does this have anything to do with the Tsunami? Also I like to run a lot of stuff at once (my old computer would slow to a crawl when I would have visual studio, udk, photoshop, adobe flash and a web browser open at once) so I was thinking 12-16GB of ram. Anyways help is appreciated, thanks in advance.
not sure the difference but I managed to find the 650D case at newegg: http://www.newegg.com/Product/Product.aspx?Item=N82E16811139006
Considering your resolution and if you want higher settings, you're looking at a new video card here.
Not a good idea: Buy as many parts as possible from Amazon.com since they do not charge CA residents tax whereas Newegg does. Not to mention free shipping on a lot of parts from Amazon.com. We've been able to shave off $100 to $300 off a California build by buying parts from Amazon.com.
I'm not gonna touch this one.
Anyway, I'm coming back in the afternoon with a build if no one else has come up with one then. It's close to 4:30 AM so sleep time now.
I will!
Just for common knowledge you can find a little bit more about Corsair at their website.
Personally I've always loved Corsair's products so spending 2 ~ 5 minutes to read about them was cool. I have 4GB of RAM from them but yet it runs and feels like much more.
/endfanboyism
Also as a more on-base related post:
How heavily will you be using Photoshop? Will it be for profit/work or just as a hobby? If it's the primary purpose of the build (which I'm assuming it isn't) then the build could be completely different.
If you are going heavy Photoshop do you use/or are planning to use CS5?
The reason for asking is because if you plan on using Adobe CS5 or future versions of Adobe, you'll want to upgrade to a better Nvidia card as Adobe software takes advantage of Nvidia's CUDA tech.
Also could you give the specs of your
An SSD could be a huge upgrade, especially with a $1500 budget.
Prelim build:
$315 - Intel Core i7-2600K CPU
$130 - MSI P67A-G43 Intel P67 ATX Motherboard
$156 - Patriot PSD34G13332 4GB DDR3 1333 RAM
$238 - Crucial RealSSD C300 CTFDDAC0128MAG-1G1 2.5" 128GB SSD
$105 - Corsair 750TX V2 750W PSU
Total: $944 shipped
No photoshop is a hobby, but I do use CS5.
What do you suggest? Is a Nvidia GTX570 a big upgrade from a 460? Would a 750watt psu handle that card?
Prelim build:
Total: $944 shipped
That looks great. You really go out of your way to help people don't you? I am torn between getting a gtx570 now or using my gtx460 until the next gen comes around.
What do you suggest? Is a Nvidia GTX570 a big upgrade from a 460? Would a 750watt psu handle that card?[/QUOTE]
Yes the 570 is a big upgrade over the 460. Yes the 750W PSU listed above will be enough.
If Photoshop is just a hobby and will remain so, then I wouldn't go with the GTX 570 then. I recommend the HD 6950 1GB card then:
$235 - XFX HD-695X-ZNFC Radeon HD 6950 1GB PCI-E Video Card
That I do.
I only have 1 more question. The RAM that was linked did not have heat spreaders. It gets really hot in southern CA in the summer and I was wondering if this is a big issue or not. I was also going to use the retail heatsink for the CPU and that would be sufficient, but honestly I dont know what the limits are for RAM in this heat.
I live in SoCal too: Those heat spreaders aren't really needed unless you have spectacularly shitty cooling in your case. I've had/have RAM with no heatspreaders running for years now in hot and sunny SoCal.
With that said, a 3rd party HSF might be a good idea especially with the heat wave hitting us now:
$32 - Cooler Master Hyper 212 Plus HSF for LGA 1366 and LGA 1156
