I've been struggling hard with a mostly new build I put together last week. My current thinking is that both the motherboard and one stick of RAM are no good. But I really am unsure so trying to see what others think.
These are my new components. Everything else came from my old build and definitely are working fine.
Processor: AMD Phenom II X6 1055t
Motherboard: Gigabyte GA-890GPA-UD3H AM3
Memory: 8GB (4x2GB) Corsair XMS3 DDR3 1333MHz
Case: Cooler Master CM690 II Basic
I have installed XP, Vista, and 7 each a couple times while testing though most of my use has been in XP and Vista. Here are symptoms I have experienced:
Frequent blue screens and program crashes
- Most of the time Windows loads fine and I can use it for awhile, sometimes for hours, but I've gotten plenty of blue screens and random programs crashing
Often start up and shut down is extremely slow
- Sometimes it is fast but often it takes several minutes. It is almost always real slow in XP.
Network/Internet not detected at startup
-Vista sometimes reports no ethernet cable plugged in when it is after booting up. Have to reboot to restore connection. Never experienced this in XP.
My first thought was RAM and I've been testing with Memtest86+. Summary: At least 1 of the 4 sticks seems bad. I am pretty sure 2 are good and the other needs more testing.
However, when using RAM that appears to be good I am still getting blue screens. One more thing I've noticed is a floppy drive appears in Windows explorer when no floppy drive is plugged in unless I disable it in device manager.
Right now I'm running Memtest86+ again on the two RAM sticks I'm nearly positive are good. If I get no errors after at least another 12 hours or so I think I should return the motherboard to Newegg for replacement. I wish I had other parts to swap in to test but all the parts I have are Intel/DDR2. This is my first AMD build and first DDR3 motherboard. What do you think?
