flashxpoint6
- Jun 25, 2011
Hello, Im building a new computer for gaming and I'm having trouble getting it up and running there seems to be an intermittent problem and I'm not sure what if any of the components may be causing the issue. The computer will post some times and not others, if it does post it hangs when entering bios or the furthest I've got was about 2-3 minutes into loading windows 7 before the computer hung up again. I've tried pulling the hard drive and DVD and just trying to get it to consistently post with the ram, processor and graphics card. I've also tried instead of all 4 ram modules just using two which did not make much difference. When the computer does post with all the ram installed it shows up as the full 8 gig in the bios however the motherboard has a memcheck button, which im not familiar with. does this sound like a memory issue or something else. Any suggestions would be very appreciated thank you in advanced.
The system ahs the following components
Motherboard- Asus Crosshair V Formula AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Gaming Motherboard with 3-Way SLI/CrossFireX Support and UEFI BIOS
Processor- AMD Phenom II X6 1100T Black Edition Thuban 3.3GHz, 3.7GHz Turbo 6 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Six-Core Desktop Processor HDE00ZFBGRBOX
Ram Corsair DOMINATOR 8GB (4 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMP8GX3M4A1600C8
Graphics- MSI N460GTX CYCLONE 1GD5/OC GeForce GTX 460 (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
Hard drive- Western Digital VelociRaptor WD4500HLHX 450GB 10000 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
PSU- Corsair 650 Watt
