WoW - this is the only game I play and the reason for this build. Will lightly use it for @ home work use (mainly MS office, RDP, web browsing)
$700ish, little flexible not to exceed $900
USA, Asheville, North Carolina
Motherboard, case, power supply, ram (8GB minimum), storage: SSD (256 is fine) for OS and apps, hdd for storage, video card, optical drive, gigabit ethernet card, wireless network adapter
None, building from ground up
6) Will you be overclocking?
No
Two Dell 24" 1920x1200
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Prefer USB 3
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Yes Win7x64
THANKS!!!
No
ASAP
Prefer USB 3
Yes Win7x64
THANKS!!!
