New build for my dad...
Lone_Star_Lynch
So we just sold an old work truck, got 1000 dollars coming in from it that my dad will spend on a computer.
I've picked out a couple of parts so far, but I'm seeking a little advice...
First of all, are this motherboard and these RAM sticks compatible?
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130184
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148070
I'm always wary of the RAM because I bought some a while back that never worked in my brother's computer though I thought they would.
Yes that Asus Maximus II Formula will support lower speed RAM like that Mushkin RAM. But you may not be able to fit either the RAM or motherboard due to your $1000 budget.
So to help you better, please answer these questions:
- Please list out every single part that you need for $1000
- What are you planning on doing with this PC? Gaming? Internet browsing or word processing?
- Will you be overclocking?
- What size monitor do you have?
- What features do you want in a motherboard?
Here's a list of other motherboards to look at:
Gigabyte GA-EP43-DS3L Intel P43 Motherboard - $90
MSI P45 Neo3-FR Intel P45 Motherboard - $112
Gigabyte GA-EP45-DS3R Intel P45 Motherboard - $130
Asus P5Q Pro Intel P45 Motherboard - $140
Biostar TPower I45 Intel P45 Motherboard - $150
DFI Lanparty DK X38-T2R Intel X38 Motherboard - $180
Asus P5E Deluxe Intel X48 Motherboard - $220
DFI Lanparty DK X48-T2R Intel X48 Motherboard - $220
Gigabyte GA-X48-DS4 Intel X48 Motherboard - $225
Just to help you out: All of these motherboards have PCI-E 2.0 which may be useful for future GPU upgrades. If you don't need RAID, more than 6 SATA ports and only need semi-decent overclocking, check out the DS3L. If you need 8 SATA ports, RAID, 4 PCI slots, and legacy ports, then get the Neo3-Fr. If you don't need more than 6 SATA ports but want RAID, firewire, a second PCI-E x16 port, a second gigabit port, support for 16GB of RAM, optional eSATA, x8/x8 Crossfire, and great overclocks, then get the DS3R. If you like the DS3R but need 8 SATA ports, want an onboard pre-installed fast booting Linux setup, just support for 8GB of RAM, and don't need a second gigabit port, get the Asus P5Q Pro. If you want a motherboard with excellent overclocking capabilities above all else (feature wise), go with the I45. If you want Crossfire with full x16/x16 bandwidth, get the Lanparty DK X38. If you have cash to burn, need x16/x16 Crossfire, and don't give a damn about getting the most value for your money, get the Asus, DFI, or Gigabyte X48 motherboards. Do note that the Asus website can be slow sometimes.
And I recommend this RAM kit:
G.Skill F2-8000CL5D-4GBPQ 2 x 2GB DDR2 1000 RAM - $80
