New build for my bro
DarkKiller
1) What will you be doing with this PC?
Primary use for this system will be Multi-boxing EQ2 as well as other assorted games like starcraft 2 etc.
He is looking to pay a total of no more than $800
Sacramento area, Ca
4) What exact parts do you need for that budget? CPU, RAM, case, etc. The word
Cpu, gpu, mobo, ram, hdd, case, cooler, psu
5) If reusing any parts, what parts will you be reusing?
1920x1080 monitor 24" , keyboard, mouse
6) Will you be overclocking?
Would like to
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Nothing in particular. Maybe typical usb 3.0 sata 6gb
Yes. Win 7 64
He seems to be of the mind that a 6 core amd would be the best way to go given the budget. Even over the i5 to be able to run 6 instances of the game smoothly. EQ2 also seems to be more RAM happy than anything else so he was thinking about 1-2gb per instance as well.
So far we have come up with:
Intel Core i5-4670K $240 http://www.amazon.com/gp/product/B00CO8TBOW/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
XFX ATX 550 Power Supply - P1550SXXB9 $61:http://www.amazon.com/gp/product/B004RJ8EKI/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Kingston Hyper X Blu 8 GB $55 x 2= 110: http://www.amazon.com/gp/product/B0057Q4ADU/ref=ox_sc_act_title_3?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Seagate Barracuda 1 TB HDD $65:
http://www.amazon.com/gp/product/B005T3GRNW/ref=ox_sc_act_title_4?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
MSI Micro ATX DDR3 1333 LGA 1150 Motherboards B85M-G43: $80
http://www.amazon.com/gp/product/B00D12OAVE/ref=ox_sc_act_title_5?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Gigabyte AMD Radeon HD 7950 3GB: Repackaged $210
http://www.amazon.com/gp/product/B007581QHG/ref=ox_sc_act_title_6?ie=UTF8&psc=1&smid=A2L77EE7U53NWQ
Corsair Carbide Series 200R $60
http://www.amazon.com/gp/product/B009GXZ8MM/ref=ox_sc_act_title_7?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Thermaltake Frio Overclocking Universal CPU Cooler: $50
http://www.amazon.com/gp/product/B003DW0GO2/ref=ox_sc_act_title_8?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
With this i5 setup we are at about $950 which is 150 over budget.
If your bro doesn't mind the extra heat and power usage, his best bet for a multi-boxing setup would be an AMD eight core setup. The extra cores would help out. If we were talking about one single game instance, I would definitely recommend an Intel setup. But since we're talking multiple game instances, go AMD.
All right, to get closer to his $800 budget, swap out the CPU and motherboard for the following:
$154 - AMD FX-8320 CPU
$88 - Asus M5A97 AM3+ AMD 970 ATX Motherboard
Total: $242 shipped
With that said, if your bro is willing to stay way over budget, then I highly recommend getting this AMD CPU due to its higher clock speed:
$180 - AMD FX-8350 CPU
As for the RAM, that Kingston RAM isn't the best choice since getting two of those sets already means you're mased out at 16GB of RAM. If your bro has Windows 7 Pro and above, then I highly recommend getting this RAM instead since it will allow him to upgrade to 32GB of RAM later on:
$119 - Crucial BLS2CP8G3D1609DS1S00 Ballistix Sport 2 x 8GB DDR3 1600 RAM
If he only has Windows 7 Home, then those Kingston RAM will be fine.
If you still need to shave off some money, then I recommend this case instead:
$43 - NZXT Source 210 Elite White with Black Front Trim ATX Case
If you still need to shave off even more money, then drop down this HSF:
$33 - Cooler Master Hyper 212 Evo HSF
Even if you were going Intel and plan on overclocking, the setup you posted would not have worked since you need a Z87 motherboard to overclock Intel CPUs. You chose a B85 motherboard.
