New Build! For image processing and more...
techbob
The most demanding thing will be Lightroom 4 and Photoshop.
Under $500
USA
CPU - I've used AMD in the past, will consider INTEL this time around
Motherboard - I don't want to skimp here
GPU - something low end should do since not for gaming.
RAM - 8GB minimum
Will pick up one or new drives for RAID 1 (mechanical not SSD, and this will not come from the $500 budget)
CPU Cooler - maybe liquid cooled but that's a whole 'nother thread!
CASE - Antec Solo (ATX)
PSU - Antec NEO ECO 520C 520W 80 PLUS Certified
Keyboard, mouse, DVD Drive, etc.
6) Will you be overclocking?
Maybe - open to it
Lenovo 1680x1050? 23" have to double check
In the next month.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
*RAID (will use RAID 1 for OS)
*USB 3.0
*APU - would be nice but AMD not there yet...
Will buy OEM Win7 64bit.
I'm looking for low power and quiet.
Thanks!
Is the cost of the OS part of that $500 budget?
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504 3570k with hd4000 for graphics $250
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128545 Gigabyte Z77 UD5H motherboard $190
or http://www.newegg.com/Product/Product.aspx?Item=N82E16813128544 Gigabyte Z77 UD3H for $160
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233196 Corsair vengeance 8gb ddr3 1600 1.5v $50
if you get the UD3H motherboard and save that $30, I would put it into this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065 Hyper 212 Plus heatsink/fan $30
$490(with high end mobo) + whatever shipping.
$313 - Intel Core i5 3450 + Gigabyte GA-Z77-D3H Intel Z77 ATX Motheboard Combo
$76 - 2 x G.Skill Value Series F3-10600CL9D-8GBNT 2 x 4GB DDR3 1333 RAM
$60 - Galaxy 43GGS8HX3SPZ GeForce GT 430 1GB PCI-E Video Card
$30 - Cooler Master Hyper 212 Plus HSF for LGA 1366 and LGA 1156
Total: $479 shipped
Notes:
- That combo expires on the 31st of this month
- Liquid isn't the best option if you want something quiet. The all-in-one liquid coolers you see from Antec or Corsair aren't actually that quiet due to the noisy pump they have. The actual water cooling are quiet but costs $300 to $400 minimum. So from a price to performance standpoint, you're better off with an air cooler. The Hyper 212+ is fairly quiet and is well priced.
- Adobe software can take advantage of Nvidia's CUDA tech. As such the inclusion of an Nvidia card should speed up your Adobe applications in some way.
Honestly I assumed he would be using CS6, which is more widely accelerated. Guess I should have asked.
This is great info - thanks so much!
Are there suggestions for an AMD CPU based system?
8120 CPU and a 970 or 990 based motherboard. AMD would actually be a decent option based on your usage and budget except for the fact that you requested a low power system. AMD CPUs use significantly more power than their Intel counterparts
This is for a home pc and will be idle most of time.
Idle wattage according to:
http://www.xbitlabs.com/articles/cpu/display/amd-fx-8120-6100-4100_8.html
FX-8120 43w
i5-2500 46.6
So it's a wash for idle power consumption. Everything considered - the Intel processors are looking good overall.
That idle seems a little high must not be using any power saving features.
I know my 2500k idles at around 10w and same goes for my old 965 BE
