speedlever
- Sep 29, 2006
If you're gonna ask us to build/list a PC for you or seek advice about a build, please answer all of the following questions:
This system is for a relative and to replace an aging Dell Dimension 5150.
General home use, medical transcription, photos, web browsing, skype, iTunes.
Not that tight. $1000, +/-.
US. NC.
Case, psu, mobo, cpu, ram, fans, SSD and/or HD, have a couple of 300 GB sata drives, media reader, dual optical drives, lots of USB 2 and some USB 3 ports for future use, Win 7/64 HP.
I think the only things usable off the old Dell will be the old 300 GB sata HDs, and possibly the optical drives, but am figuring on replacing the optical drives. I might be able to use the media reader as well, but will plan to replace that too, just in case. Oh and the 2007FP display and wireless USB keyboard and mouse.
6) Will you be overclocking?
No.
Dell 2007FP. 20 inches - 1600x1200.
Within the next 2 to 4 weeks.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
Onboard video should be fine as provided by HD Graphics 2000 or 3000. Sata 3Gb/s for sure, it might be nice to have some Sata 6 Gb/s for the future. No raid or FW needed. Lots of rear USB 2 and some 3 ports, minimum of 6 total for starters.
Current system is using OEM XP/home as provided on the Dell Dimension. I plan to get a Windows7/HP upgrade.
My current thoughts are as follows:
Case: Corsair Carbide series 400R or maybe 500R or other case that meets the below specs. It doesn't have to be fancy, and no lights or side panel windows. I don't like how the P183V covers up the external drives. And the top mounted controls on the Corsair could be problematic.
The case sits on top of a crowded desk, and the top of the case generally holds the router and a cordless phone base, so top exhaust fans and top mounted controls may pose a problem. It's not uncommon for heavy dust to build up which may impede cooling... until I notice it and vacuum it.
Externally, I would like to see dual 5.25 inch and a single 3.5 inch drive bays for the optical drives and media drive. Also, multiple front USB 2.0 and possibly 3.0 ports. Front audio connectons are not needed.
Internally, I expect a possible SSD, a Sata 3.0 1TB or 2TB HD plus a Sata 2.0 2TB backup drive and maybe 2 existing Sata 2.0 smaller HDs.
PSU: I'm thinking SeaSonic X650Gold or Corsair HX650, either in the $130 range. I want a modular PSU.
Mobo: Although not an Asus fanboy, I like Asus because that comprises the majority of mobo's I've had, other than OEM mobos and one ASRock (which is fine.) I just built a P8Z68V Pro system, and lean to that one for familiarity, UEFI, all the ports I think needed. But Gigabyte, MSI, and ASRock would also be fine if they provide the connectivity needed. I don't believe Esata will be a requirement on this build.
CPU and cooler: I'm thinking core i5-2400. No OC. Just reliable and at least a 5 year service life. (the old Dell is over 5 years old.) For the HSF I'm thinking CM Hyper 212+ plus additional Blademaster 120mm fan for a dual fan arrangement.
Graphics: I suspect HD Graphics 2000 will suffice.
Ram: 4x4Gb DDR3.
Storage: SSD? I have an X25-M and really like it. While I know that SSDs are not immune to failure, I moved to an SSD after having two conventional OS HD failures in 12 months. How about an Intel C320 or 510? The problem is that the user(s) will not care or think to store routine stuff on a separate HD and keep the SSD(C:\) for OS and programs (as much as can be.) Plus, too many programs hardcode the storage place and don't give the option.
Or maybe a compromise might be appropriate here. Get a 64Gb SSD and use it with Intel's RST and a fast TB HD. ???
And regarding storage, what the heck has happened to HD prices? I bought a Sammy HD204UI 2TB drive a few months ago for $80 and now they're going for $230. ???
Considering the compromise setup:
What 64Gb SSD? Crucial C300 or M4 or Samsung 830 series?
Hard drive in conjunction with small SSD:
WD 1 TB SATA3.0 drive
Backup drive:
Samsung 1 TB SATA 2.0
Thanks in advance for your thoughts and suggestions.
Wow. I just did a quick run through: $1400 thus far. May have to trim that a bit.
Case: $160
PSU: $133
Mobo: $210
CPU: $190
Cooler: $43
RAM: $96
SSD: $115
HD1: $205
HD2: $80
Media reader: $27
Optical drives: $40
Win7/hp upgrade: $110
US. NC.
No.
Ram: 4x4Gb DDR3.
Backup drive:
Case: $160
PSU: $133
Mobo: $210
CPU: $190
Cooler: $43
RAM: $96
SSD: $115
HD1: $205
HD2: $80
Media reader: $27
Optical drives: $40
