I'm building a new system to replace my Q6600 system and will not be carrying over anything from the old system except keyboard, mouse and monitor.
Gaming and web browsing.
2) What's your budget? Are tax and shipping included? 1500-2000. Will spend higher if results justify it.
3) Where do you live?
Jackson, MS
CPU, 8 GB Ram, Case-big enough for a 580, Powersupply, cooling solution (H70?), OS-Win 7 Home Premium, BD/DVD player/DVD Writer, Hard Drive, SSD
Only possible reusable part would be the Creative Titanium soundcard, not a priority now.
6) Will you be overclocking?
Yes, although system stability is my goal.
24 inch 1900x1200. May go for a larger screen down the road.
In the next week.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
I won't be doing crossfire, I tend to get the top single card solution and upgrade it once or twice along the way. Firewire doesn't matter, USB 3 and SATA 6 is important.
I'll get a new OS for the system-64 bit Win 7 Home Premium. Current build is Win 7 Pro but I don't need XP mode.
Just some general comments. My current case is a Thermaltake Armour and I like a nice well ventilated case. I am interested in a SSD, which I don't have and am a bit unsure of what size and brand to get.
Budget is flexible, 1500 seems to be a reasonable SB layout and I'll go up on that if I can get extra performance.
Thanks for the help!
Jackson, MS
In the next week.
