New build feedback?
Mundar
This is what I have in mind for my new build. Anyone have any suggestions on what I should change?
Any type of feedback would be greatly appreciated.
Gaming (BF3). Adobe editing programs (Photographer). Of course web browsing.
~$1200 not including shipping and tax.
3) Where do you live?
Northridge, CA
Everything necessary to build a new box. Case, CPU, RAM, PSU, Mobo, Hard Drive, CD drive.
GPU: GeForce GTX265. Thermaltake TMG i2 CPU cooler. Kingston 128GB SSD.
6) Will you be overclocking?
Yes.
23 inch LG 1920x1080
Within the month.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
All of the above would be preferred. SLI, USB3, SATA6
Windows 7 Ultimate 64-bit
Please answer the stickied "ANSWER THESE QUESTIONS FIRST!" so that we can help you better.
What's the priority of this build: Gaming or Photoshop?
Why are you going with a Blu-ray drive?
Actually, you don't need a Blu-ray burner for your intended use. In fact, a Blu-ray burner is overkill for your system unless you intend to frequently archive high-definition videos onto a format that's compatible with standalone Blu-ray video players. Indeed, you can save $110 by getting a SATA DVD burner instead of the Blu-ray burner.
Second, ditch that WD1001FALS hard drive: Most versions of that drive are actually significantly slower than a much cheaper Samsung F3 HD103SJ drive because you'll likely receive an older (and original) 3-platter version of that drive (due to the fact that Western Digital continues to make old and new designs alongside one another - and often on the exact same day). I ranted about Western Digital some time back for that company continuing to produce both old and new revisions of the exact same model drive at the exact same time.
In addition to E4g1e's advice:
1) Try to get as much of your parts as possible from Amazon.com since they do not charge CA residents tax.
2) Try to buy this RAM in the next 5 hours:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
Use this promo code with it: EMCKHJE54.
If you can't use the promo code, then don't buy the RAM. But $82 shipped for 8GB of DDR3 1600 RAM is a freakin' steal. And no, there's no difference between triple and dual channel RAM. So the above set would get you an extra 2GB of RAM as well as leave room for even more RAM upgrades.
My priority is both gaming and Photoshop. I would also like to make this box somewhat future proof, I want it to last about five years, just like my old box.
What do you think about adding another 6GB of RAM? So I would have a total of 12GB.
This is on sale right now for $58:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145222&nm_mc=EMC-IGNEFL021711&cm_mmc=EMC-IGNEFL021711-_-EMC-021711-Index-_-DesktopMemory-_-20145222-L0E
At $75 shipped and taxed, not that great of a deal. No we don't factor in rebates around here since they're not guaranteed.
I agree. In fact, it is a tad expensive for so-called "DDR3-1600" RAM that needs 1.65V to run at its advertised speed and timings. Realistically, at the JEDEC voltage standard of 1.5V, it is really only a true DDR3-1333 kit. (There are currently no JEDEC DDR3-1600 kits yet on the market, so all "DDR3-1600" memory currently out there are simply native DDR3-1333 DIMMs with XMP profiles for the 1600 speed.)
I agree, stay with a 1.5v modual. I dont think the 1.35V moduals are worth thier money.
