Ive learned a lot from this group over the weeks of planning my new build. Much of the input youve provided others has helped me spec out a system that works for me (I hope). My objective is to piece together a budget gaming rig (approx. $1,000) that is STABLE and fast. Since gaming is not the only activity (general productivity, some light video editing) and the box will be used by more than one family member, I really need this thing to simply work all the time, with very few complications. I dont plan to overclock for the first few weeks/months until I make sure things are operating as planned. Also, my OS is XP Pro.
That being said here are the components Id like to use for this build (replacing a build I did about 4 years ago). Id appreciate your collective wisdom/thoughts (all model names from NewEgg website):
Motherboard: ABIT IP35 Pro LGA 775 Intel P35 ATX Intel Motherboard - Retail
Questions: Does its support for onboard 1394 and onboard USB mean I can run cables from the mobo to the USB and Firewire ports on the front of my case? I dont need Firewire port in back but I do need one in front. My optical and hard drives (only one of each planned) are both SATA so the 6 SATA on the board should cover me now and in the future.
CPU: Intel Core 2 Duo E6750 Conroe 2.66GHz 4M shared L2 Cache LGA 775 Processor Retail
CPU Cooler: ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler - Retail
RAM: CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Retail
Questions: Does this RAM work with this board? Is it stable? I had considered DDR2 1066 (cant remember the manufacturer) but am worried about stability. I could use some suggestions in the RAM department.
Video Card: XFX PVT88PYDF4 GeForce 8800GT 512MB 256-bit GDDR3 PCI Express 2.0 HDCP Ready SLI Supported Video Card - Retail
Questions: I want a DX10 supported card so Im set for the next few years. But I honestly cant keep it all straight in the video card department. So many passionate opinions in this area. Im currently using an old 19 4:3 LCD monitor but expect to upgrade to a 22 widescreen (Max Resolution: 1680 x 1050) in the next 3 months. I play WoW, Call of Duty 4 and some others, but I really dont need to max out something like Crysis. After reading these boards Ive determined I have no need for SLI (thus my mobo choice above). I want one good card that will hold me for a while. Does this card, with its SLI support, work in my non-SLI mobo? Do I need 3rd party cooling since it wont be overclocked? Will it fit in my case?
Hard Drive: Seagate Barracuda 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive OEM
Questions: SATA connection should work nicely with mobo. 7200 is probably fast enough for me (especially given my budget). I will have a big external Seagate as my backup drive. Really trying to keep things simple. I have read about having two drives, one 10000 RPM for apps and a 7200 for storage, both internal. But that seems like overkill to me.
Optical Drive: SAMSUNG Black 18X DVD+R 8X DVD+RW 8X DVD+R DL 18X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA DVD Burner With LightScribe Technology - OEM
Questions: Again, keeping things simple. I dont need a second optical drive. I just want one that works and I dont need the fastest burn rates because I dont burn discs that often.
Power Supply: CORSAIR CMPSU-550VX ATX12V V2.2 550W Power Supply 90 - 264 V UL, CUL, CE, CB, FCC Class B, TUV, CCC, C-tick - Retail
Questions: Need help here. Id like to keep it below $100 and Id like it to be reasonably quiet. This one is $85 after rebate, but I wonder if its more than I need? I dont think I need it to be modular.
Case: Antec Solo Black/Silver Steel ATX Mid Tower Computer Case - Retail
Questions: Does this case provide enough room for all of the above components? Does it have good airflow? I like simple cases, without windows and bling, but I want front side USB and Firewire. In a perfect world Id like to get LIAN LI PC-A05B Black Aluminum ATX Mid Tower, but Ive read it makes things run hot because PSU is in front bottom and its cramped. For the Antec, I can order B Stock from the Antec website.
Your thoughts for other folks have really helped me get this far. Now Id love to see what you say about my choices.
Thanks!
Thanks!
