New build coming up
Bunkalnarf
Alright this will be my first build since the summer of '03. I am excited to fianally upgrade from my Athlon XP2500 box.
I am hoping to get some nice over clocking mileage on the e4300.
Any feedback is appreciated.
Intel Core 2 Duo E4300 Dual Core Processor LGA775 1.8GHZ 800FSB 2MB Retail
Gigabyte GA-965P-DS3 ATX LGA775 Conroe P965 DDR2 PCI-E16 3PCI-E1 3PCI SATA2 GBLAN Audio Motherboard
OCZ Gold XTC PC2-6400 2GB 2X1GB DDR2-800 CL5-5-5-12 240PIN DIMM Dual Channel Memory Kit
BFG GeForce 8800GTS OC 550MHZ 320MB 1.6GHZ GDDR3 PCI-E Dual DVI-I HDTV HDCP DIRECTX10 Video Card
Noctua NF-S12-1200 120MM Ultra Quiet Cooling Fan 1200RPM 81M3/H 17DBA Molex
Arctic Cooling Freezer 7 Pro LGA775 2500RPM 45CFM
Antec P182 ATX Black Mid Tower Case 4X5.25 1X3.5 6X3.5INT No PS Front USB Audio Firewire
OCZ Stealthxstream 600W ATX12V 20/24PIN Active PFC ATX Power Supply 120MM Fan Black
Seagate Barracuda 7200.10 320GB SATA2 3GB/S 7200RPM 16MB Cache NCQ Hard Drive
Samsung SH-S183L Black SATA DVD+RW 18X8X16 DVD-RW 18X6X16 DL 8X Lightscribe DVD Writer OEM W/ SW
Microsoft Digital Media Keyboard & Optical Mouse Combo Black PS/2 OEM
Microsoft Windows Vista Home Premium Edition 32BIT DVD OEM
I would not buy a 965 based board at this point in time. Get the DS3R instead of the DS3, or another P35 based board. You could also save some money by going with a 650i board, but that could limit your overclocking potential somewhat.
G.Skill DDR2-800 is likely less expensive, and you won't have to deal with rebates -- I didn't get my OCZ rebates in on time, as they have a very short grace period, so fair warning there.
The P182 costs more for no real reason now that the P180 has been revised. Save some cash and get a P180B instead.
I don't know about that specific PSU, but some OCZs have ripple issues. I'd go with the Corsair 520watt or 620watt if budget will allow.
If you want to OC paying for a better HSF is a good idea. A Tuniq Tower will do a good bit better than that Arctic Cooling Freezer 7 Pro.
Most importantly: What resolution are you looking at? 1600x1200 or higher? If so, get the 640MB 8800 GTS instead. You will run in to VRAM limitation issues with the 320MB card, particularly with moderate to high levels of AA/AF on.
Moshiach: This will be my main day to day box, x264 encoding, gaming ( not heavy amounts), and everything else. I don't need bleeding edge seeing as I am still putting along with my old Athlon rig. But I am looking for a major upgrade, it's been way to long.
My budget is in between $1400-$1500 roughly, but if I feel it is worth it a little can be added, that budget is before taxes in Canadian dollars. I will be buying all my parts from NCIX.com.
silent-circuit: For a mother board with this be suitable?
http://www.ncix.com/products/index.php?sku=24650&vpn=GA-P35-DS3R&manufacture=Gigabyte
The OCZ is cheaper even without the rebates, is there any real performance issues or is the OCZ fine?
On NCIX the P182 black is $9 dollars cheaper then the P180 black, go figure.
I have never heard of the ripple issue, can you enlighten me?
The Tuniq Tower looks like a solid decision for only around 25-30 dollars more. I just want to verify that it does come with it's own 120mm fan.
For the foreseeable future I will be running at 1440x900.
I would suggest getting 64 bit vista. 32 bit seals you at 4GB and more likely vista is going need 4GB or more for it gaming sweet spot.
Yes, the board you linked is a good, solid board with 45nm CPU support, so upgrading your processor later is an option as well.
The Tuniq Tower does come with its own fan, unlike the Thermalright Ultra 120 Extreme. (the Ultra 120 is probably the best air cooler on the market right now, but... it's huge, just like the Tuniq, and pricey.)
At 1440x900 a 8800 GTS 320MB should be fine, but if the price differential isn't huge I would still go for the 640MB card to be certain you will be able to run high levels of AA and AF. However, if you're not heavy in to gaming, the 320MB card should suit just fine. In fact, the 320MB /should/ be fine, period.
I think it's just the Gamexstream line that suffered from ripple (very fast fluctuations up and down on the rails, particularly the 12v rails, which can kill components over time) but I'm not certain. I will try to find out if the model you picked has similar problems.
I have 2GB as shown in my sig and have yet to see any real difference in framerates from those running 4GB. I'm running Vista Ultimate 32bit.
I've been happy with my $4 each Yate Loons (and they were buy 2 get 1 free when I got them), so to me that Noctua fan looks like overkill of an extreme nature, but that's entirely up to you. There's no denying that they're quieter, but I also believe they don't push near as much air... and you can get like 12 Yate Loons for the price of one of them. ;)
I hear you on that, so in the end I am switching out the OCZ power supply for the Corsair
520watt, I am looking forward to a modular power supply too.
Thanks for the all the help.
I am going to be putting the order in within the next day or two.
Any last comments?
1 x Intel Core 2 Duo E4300 Dual Core Processor LGA775 1.8GHZ 800FSB 2MB Retail
1 x Gigabyte GA-P35-DS3R ATX LGA775 Conroe P35 DDR2 1PCI-E16 3PCI-E1 SATA RAID Sound GBLAN Motherboard
1 x OCZ Gold XTC PC2-6400 2GB 2X1GB DDR2-800 CL5-5-5-12 240PIN DIMM Dual Channel Memory Kit
1 x EVGA E-GEFORCE 8800GTS 500MHZ 320MB 1.6GHZ GDDR3 PCI-E Dual DVI-I HDTV HDCP DIRECTX10 Video Card
1 x Sunbeam Tuniq Tower 120 S754 S939 S940 S478 LGA775 Heatpipe Cooler 120MM Fan CPU Heatsink
1 x Antec P182 ATX Black Mid Tower Case 4X5.25 1X3.5 6X3.5INT No PS Front USB Audio Firewire
1 x Corsair HX520 CMPSU-520HX 520W ATX Triple 12V 40A Continuous 24PIN ATX Modular 120MM Power Supply
1 x Seagate Barracuda 7200.10 320GB SATA2 3GB/S 7200RPM 16MB Cache NCQ Hard Drive
1 x Samsung SH-S183L Black SATA DVD+RW 18X8X16 DVD-RW 18X6X16 DL 8X Lightscribe DVD Writer OEM W/ SW
1 x Microsoft Digital Media Keyboard & Optical Mouse Combo Black PS/2 OEM *With System Only*
1 x Microsoft Windows Vista Home Premium Edition 32BIT DVD OEM
