CookieFactory
- May 17, 2006
Right now my system consists of an Antec P180, Asus P5W DH Deluxe, Intel E6700, Intel X25-M 80 GB, and Radeon HD5870, however I am starting to notice FPS lag in several newer games (ME3, BF3, Witcher 2, Deus Ex: HR, etc).
General purpose. Web browsing and gaming would probably be the top 2 activities. The games I'm planning on playing are Guild Wars 2, BF3, League of Legends, etc.
No hard budget per se, but ideally under 2k USD.
Ohio, and a Micro-Center is less than 20 minutes away.
Case
Motherboard
CPU
CPU heatsink
CPU fan
GPU
OS Drive
PSU
RAM
I will be re-using a 1 TB WD Black HDD for media / non-OS
6) Will you be overclocking?
Perhaps a modest overclock. My current system is running at stock speeds although I have run at 3.4 GHz on and off.
2 x 24" 1920 x 1080
Really up in the air. If I can get away with using my current PC, then perhaps not until Haswell. Otherwise within the next month or so.
9) What features do you need in a motherboard?
USB 3.0, eSATA, and I'd like to have built-in Bluetooth as I have had poor luck with USB bluetooth adapters (planning on using a Bluetooth mic, headset, etc).
Yes, Windows 7 Professional x64.
Here is what I've tentatively picked out:
Case: Silverstone FT02B-W - $239
Motherboard: ASUS P8Z77-V DELUXE - $283.49
CPU: Intel 3770K - $309.56
CPU heatsink: Prolimatech Megahalems Rev C - $76.55
CPU fan: ??
GPU: SAPPHIRE Radeon HD 7950 - $399.99
OS Drive: Intel 520 240 GB - $330.99
PSU: SeaSonic Platinum Platinum-860 - $219.99
RAM: G.SKILL Ripjaws X Series 8GB x 2 - $93.98
Total Cost: $1953.55
What do you think of this build? Are there any components you would recommend instead? I would like to keep power consumption, heat, and noise as low as possible without them becoming primary drivers. Thanks for any feedback.
Case
Motherboard
CPU
CPU heatsink
CPU fan
GPU
OS Drive
PSU
RAM
2 x 24" 1920 x 1080
CPU fan: ??
