New build(budjet 700)
Kais3r
I finally got 350 enough for half of my computer(parents pay other half ) this is my build that i've been looking at for around 2 months. I'm going to order this tonight so please tell me if the parts are compatible.
I know the video card sucks but I will upgrade at christmas, it will be fine for americas army.
CASE &PSU:
Code:
http://www.microcenter.com/single_product_results.phtml?product_id=0257459
89.99
Harddrive:
Code:
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136218
Memory:
Code:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
Motherboard:
Code:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128337
Processor:
Code:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
64 BIT VISTA:
Code:
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116204
TOTAL
711.93 after rebates before shipping. What do you all think of this build.
I'd go dual-core and apply the money elsewhere.
Quad-core is severly overrated for the majority of people.
just my $0.02.
Get the DDR2-1000 G.Skill RAM for the same price. They're probably pretty much the same RAM, but I would assume that the DDR2-1000 sets have been tested to work up to that speed. You can still set the DDR2-1000 kit at 800 and lower the voltage. If you don't mind Mail-in rebates, you could look at some other 2x2GB sets from other brands to save a bit more money.
It looks like your video card choice is now up to $101.
The rest is good.
Please list part names along with those links. Some of us charge for clicking on so many links. :p j/k
just my $0.02.
Can you list a good one for cheaper. Hell, I don't mind going AMD if I could save alot of money.
The rest is good.
Dang about the video card. I will go with that ram instead, thanks!!!
:p Well then I will go broke by paying you lol :eek:
CASE &PSU:
Code:
89.99
Harddrive:
Code:
Memory:
Code:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231145
Motherboard:
Code:
64 BIT VISTA:
Code:
NEED VIDEO CARD AND DUAL CORE PROCESSOR.
Part names... like Core2Duo E6600, 8800GT 512MB, etc... not just "case & PSU" but like, Cooler Master Centurion 534 & Corsair 450W, etc.
Seriously, some of us are on very SLOW systems that don't like us opening a BUNCH of tabs just to reply to a single post. Please help us help you. ;)
I might buy the case/PSU today since it is such a good deal.
Sonata III Silent ATX Mid Tower
89.99
Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000) Dual Channel Kit Desktop Memory - Retail
GIGABYTE GA-EP35-DS3L LGA 775 Intel P35 ATX Intel Motherboard - Retail
64 BIT VISTA HOME PREMIUM
Intel Core 2 Duo E8400 Wolfdale 3.0GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115037
649.94 without video card.
NEED VIDEO CARD STILL
Video Card: EVGA 9600GT ($150 with free shipping and $10 mail-in rebate)
Dual-Core Processor: Intel Pentium Dual Core E2200 ($80 with free shipping)
The 9600GT will work well on most monitors 20 inches and under, and the E2200 is a good CPU both at stock speeds and overclocked. I focused more on the video card in order to give you the maximum amount of versatility with games. With your $700 budget, you would have to decide upon a good processor or a good video card -- you can't have both (not without cutting corners elsewhere).
A vidcard is easier to upgrade than the CPU because of the CPU HSF. Keep in mind the vidcard is the fastest depreciating component in a gaming PC.
You've got some great part choices right there. However, if you want the best gaming performance, then the combo tiraides suggested is best. The E2200 is no slouch once you OC it, and it can OC to around 3.2Ghz. Most games are GPU dependent, not CPU dependent. Though, in order to OC that E2200 nicely, you'll need a $20 Arctic Cooling Freezer 7 Pro or CM Hyper TX-2 CPU HSF, to keep the CPU nice and cool.
Yes, get the case/PSU combo while its a good deal.
Would this vid card be better?
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130319
and do i need thermal grease?
89.99
ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186134
Intel Pentium E2200 Allendale 2.2GHz 1MB L2 Cache LGA 775 65W Dual-Core Processor - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116063
566.93 without video card/ AND MAYBE WITHOUT thermal grease...
89.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136161
706.92 WITHOUT DISC DRIVE
I JUST RELIZED I forgot a disc drive. Can somone recommend me a good 1?
TOTAL WITH BURNER COMES TO 735.91. THANKS ALL, I GUESS I CAN SCRAPE UP 35 dollars. :)
Can someone recommend me a good wireless card from newegg that will work with this system?
