Gaming, browsing, movies, etc. I bought some parts already. I just wanted to get it up and running for Diablo III and then upgrade as I have the cash.
Less than $500 for the rest of my stuff. I'd like to keep it under $1000 total for now if its possible with a good SLI/crossfire PSU and a good case.
USA. New Jersey
Case (I like having a window on the side panel. Size and noise are not concerns for me.)
HDDs (I think I'll start with a standard hard drive and add a SSD later)
Optical Drive
Power Supply (Plan on sli/crossfire in the future)
HSF
I've already purchased these parts:
GTX 460 1GB $104
8GB G.Skill Ripjaw $43
i7 2600k $285
Asus P8Z68-V LGA 1155 Z68 ATX Intel Motherboard $95
6) Will you be overclocking?
Yes, eventually. I'd like to start with a good case for air overclocking and stick with the stock HSF for now. Suggestions still welcome though.
I'll be using my 720p LCD TV to start. I plan on selling it and getting a used 30" monitor in the future.
I'd like to buy parts over the next couple weeks.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc
Already have my motherboard.
Planned on getting Windows 7 64bit
Like I said, I just wanted to get it going. I wanted to go with a cheaper video card that will work with lower resolutions now, and then upgrade when the next gen comes out.
Biggest help I need is a case.
USA. New Jersey
Optical Drive
HSF
GTX 460 1GB $104
i7 2600k $285
