seesawmcgraw
- Jun 17, 2008
this will be my 2nd build ever im much wiser this time around
last time around i bought an sis chipset and a a64 3000+ 939 off of ebay which ended up being a winchester not a venice and a sapphire x850xt which overheated the motherboard was absolutely terrible not doing that again
heres my list total price 551$ shipped with 55$ mir 1 25$ + 1 30$
GIGABYTE GA-EP35-DS3L -90$ +shipping i dont think any explanation is necessary i mean its practically a household model #
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128337
Intel Pentium E2180 -70$ Allendale if i were to spend any more i may as well get a q6600 which i cant afford
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116052
OCZ Platinum Revision 2 2GB -44$ + shipping with 25$ mir this is where i cut costs really need to drive down the initial expense it should be fine though i can always add more
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227139
ECS N8800GT-512MX+ GeForce 8800 GT 512MB 145$ + shipping last i checked the cooler itself was 30$ and that didnt look like it included the fans they were 9$ both included this way your basically guaranteed cool and quiet card and you hear all kinds of issues with peoples cards and fan speeds i can just twist tie a 120mm fan to it
http://www.newegg.com/Product/Product.aspx?Item=N82E16814134035
LG Black 20X DVD+R 8X DVD+RW 23$ again cutting costs but this should be fine
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136117
Seagate Barracuda 7200.10 ST3250410AS 250GB 60$ i dont need any more gbs
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148262
these last 2 are where im not 100% positive
case
Rosewill RZS06 SLV Black/ Silver Sturdy SECC Steel ATX Mid Tower 27$ + shipping not the best but great price and this will be my first time modding and im not skilled with tools at all so this will be nice i can go to town on this case without worrying about wrecking it i like the layout its nice that its smaller because im going to be taking this back and forth from college to home
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147088
powersupply both made by seasonic both have active pfc
Antec earthwatts EA430 60$ w/ 30$ mir inexpensive if the rebate works reliable and with the case i plan to get i like how it exhausts air out of the back it probably runs cooler than the other idk though
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371006
this is my 2nd choice i didnt pick it because it would make me have to order from another site making my order that much more complex but it is a better deal
modular more power aesthetically superior really surprised its not in the [H]ot deals
SEASONIC SS-600HT 47$ + 8$ shipping
http://www.hypermicro.com/product.asp?pf_id=PSSS003
Rosewill RTK-002 Anti-Static Wrist Strap 3.50$ +shipping good measure never hurt anyone
now i could have saved 4$ from ordering my motherboard and harddrive from zipzoomfly but id rather have 1 simple order
il probably get a ninja plus down the road and mod that case so id have 2 intake 120mm and 2 exhaust 120mm maybe add a side panel window or a handle on the top
only issue i have is im kind of terrified to flash the bios i just really dont know
case
