New Build Advice
tjwhite3
Hi,
I was hoping to get some advice regarding a new "budget" build. I'm hoping to start the build as soon as I feel comfortable that I've made the right choices in components. The purpose of the PC will be primarily gaming, as seen below.
Basically, I'd like opinions on the choices here and if there are any recommended tweaks.
Any suggestions are deeply appreciated.
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
Mobo + CPU: http://www.newegg.com/Product/Combo...-_-na-_-na&AID=10521304&PID=3891137&SID=194r0
GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16814150505&cm_re=6850-_-14-150-505-_-Product
RAM: http://www.newegg.com/Product/Produ...-_-na-_-na&AID=10521304&PID=3891137&SID=194r0
os: http://www.newegg.com/Product/Product.aspx?Item=N82E16832116754
HD + PSU: http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.514469
Cooler: http://www.amazon.com/Cooler-Master-Hyper-212-Plus/dp/B0037JT78C?tag=atmlina-20
*** Gaming (SC2, Cataclysm now -- anticipating Guild Wars 2, Diablo 3 down the road)
*** Like to stay under $1000
3) Where do you live?
*** US
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
*** Case, Mobo, CPU, GPU, RAM, OS, HD, PSU
*** DVD-RW Drive
6) Will you be overclocking?
*** No
*** 19" widescreen currently, hoping to upgrade to 22-24" later on
*** Would like to start ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
*** Wouldn't mind keeping SLI/Crossfire open as option for future upgrading
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? 32bit or 64bit?
*** No
Thanks in advance!
Everything looked good up until the PSU: Don't get that PSU. I recommend this combo instead:
$150 - Corsair 650TX 650W PSU + Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive Combo
Yeah, I'd stay away from OCZ PSUs. They really suck with their rebates.
Also, I'd check to see if that video card fits inside that case. The card is 9.5 inches long.
