new build advice
KidzMD
Ok, looking to upgrade my system as I'm currently on my last build from 2/06 - X2 4400+, X1900XT, etc... Showing it's age badly and since it's been almost 4 years is time to upgrade. Since I'm a little out of the loop on current gear, heres my info:
Gaming, video editing
$2500-3000
3) Where do you live?
ND
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Upgrading everything - case, cpu, ram, PCU, GPU, etc...
Mouse, keyboard, 1TB internal SATA drive
6) Will you be overclocking?
Most likely - not interested in watercooling though
24"
2 months (likely after Jan 1st)
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Firewire, otherwise standard stuff
10) Do you already have a legit and reusable/transferable OS key/license?
Yes
Here's what I'm thinking at this time, keeping in mind I'll probably do this in the next 2 months:
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=12282452
Thanks in advance for any tips or changes.
You ram is just for show, With the optical out on the motherboard do you really need a sound card?
The VR for the main drive? The new seagate almost are at that speed and run $55 for 500gb
You going SLI? Otherwise you can drop down to a 520hx or TP550 for a power supply.
Gskill 1600 $140
500gb seagate
The asus monitor is on sale now, don't expect it to be there next month or week for that matter.
Look at the cooler master 212+ for cooling HS.
Corsair dominatiors are very overpriced.
G.Skill ripjaws or Ocz Obsidian series can match them with simplar performance at much lower price.
http://www.newegg.com/Product/Produ...m_re=ocz_obsidian_1600-_-20-227-477-_-Product
or
http://www.newegg.com/Product/Produ...m_re=ocz_obsidian_1600-_-20-227-495-_-Product
3x if you want 12 GB of memory
Have you taken a look a Lian Li budget line "Lancool" Same looks lower price.
http://www.newegg.com/Product/Produ...0&Order=BESTMATCH&Description=lancool&x=0&y=0
I would suggest XFX over the Sapphire as you get much better warranty from XFX.
Evga x58 LE is about $70 cheap and good overclocker. 4 GHz stable overclock is very possible with this board and D0 step i7 920.
http://www.newegg.com/Product/Produ...3188049&cm_re=evga_x58-_-13-188-049-_-Product
Raptors are waste of money, SSD is the way.
http://www.newegg.com/Product/Produ...0139081&cm_re=ssdnow_v-_-20-139-081-_-Product
2x in raid 0
Thanks for the advice on the ram, just had it added as it was highest rated on newegg for 6gb at that speed.
I've looked at the lancool, but I like the solid aluminum Lian Li and I'll probably end up using this case for builds for years. I actually have a mid-tower Lian Li now I bought 5 years ago, but it's a little crowded so upping to a full tower.
The VR is for the main drive (basically just OS). I tend to keep everything else on seperate drives for if I need to reformat, I don't lose anything. Will think about an SSD instead.
Power supply I'll keep at 750 as it's give me option to go SLI if I decide to.
You're also probably right on not needing the sound card. Currently still use to motherboards having so-so onboard sound since I haven't purchased one in almost 4 years.
I'd spend the extra $5 for this better quality 750W PSU:
$115 - Antec Truepower New TP750 750W PSU
Your build is pretty similar to what I've got coming in the mail. Like Shiro said, SSD is preferable and that ram is unnecessary.
I spent ages looking for a better case, but couldn't find one that could hold my RAID array as I wanted, this case looks like it's going to be pretty nice, good choice! I'll let you know if a day or two when it gets here if it's any good if you'd like.
So if I was going to go with an SSD as my boot drive, would 40gb be big enough?
edit: Nm, thought Win7 install was alot bigger than it actually is.
Reason behind suggest a raid 0 setup is that SSD doesn't have great write speeds and as such Raid 0 would boost the performance to level where you will notice the increase in speed from regular hard disk.
