Hey guys, just looking for some advice on my new build, and im not sure what to get for a few parts.
CPU - Intel Core 2 Duo E8400 LGA775 'Wolfdale' 3.00GHz (1333FSB)
Motherboard - Looking to spend ~£100, £120 ($240) max, any suggestions?
RAM - OCZ 4GB (2x2GB) PC2-6400C4 800MHz ReaperX HPC Enhanced Bandwidth Edition Dual Channel DDR2
GFX - BFG GeForce GTX 260 OC 896MB GDDR3 TV-Out/Dual DVI (PCI-Express)
HDD - Western Digital VelociRaptor 300GB 10000RPM SATA-II 16MB Cache
Optical Drive - Samsung SH-S203P/RSMN 20x DVD±RW SATA Dual Layer Lightscribe ReWriter
CPU Cooler - Thermalright Ultra-120 Extreme CPU Cooler (Best fan for this? I use closed headphones so doesnt need to be silent. Also whats the difference between Arctic Silver Thermal Epoxy and Arctic Silver 5 Thermal Compound?)
Cases - Looking for something around £60 ($120) (Again not so bothered about how quiet it is, looking to oc a little bit so decent airflow pref) and will this fit the motherboard?
PSU - Corsair HX 620W ATX2.2 Modular SLI Compliant PSU
ANy help or comments are appreciated : )
