I was going to upgrade my existing rig in my sig and just recently got a evga 7600gs agp from newegg . But after some thought I am thinking of returning it to newegg and updating my Motherboard, CPU, Ram and replacing the 7600gs agp with a 7600GT pcie.
My budget is only around $600.
Here is what I was thinking. I would like to do some overclocking but nothing extreme, maybe getting a e6300 to around 2.4 to 2.8ghz, I would be happy with that. I consider stability more important than getting every last ounce of performance. I welcome suggestions,
Processor,
http://www.newegg.com/Product/Product.asp?Item=N82E16819115005
Motherboard,
http://www.newegg.com/Product/Product.asp?Item=N82E16813128018
Memory,
I need suggestions. I would like to get 2x1gb of memory.
GPU,
http://www.newegg.com/Product/Product.asp?Item=N82E16814130062
Everything else I would like to reuse from my current system in my sig. My only question mark? is my powersupply. I am still using the one that came with my antec case. It is a 380 watt true power. Is it enough?
Thanks for any suggestions/advice.
Processor,
Motherboard,
Memory,
GPU,
