Hey guys,
Given the price drop that I have been waiting for I am now ready to build a new rig. My current system (Intel P4 2.4C) is treating me just fine but I am going to use that as my backup setup.
I am dead set on the intro level Core2Duo chip (E4300). I am thinking that this will perform smoother when compared to the 2.4C and combining that with a PCI-E card and DDR2 sticks, it should work just fine for what I need the system to do.
So far this is what I have:
CPU - Intel E4300 (I won't be overclocking right off the bat but I do want to have the ability to do so in the near future so I will be using the retail HSF for now)
PSU - XClio 500W PSU
Now, I am not sure which motherboard to get with this. In terms of memory what should I be looking for? I do have time to scout for [H]ot deals and etc. since my current system is still running just fine. In terms of video cards, what is the best bang for you buck nowadays?
This is going to be a budget system so taking that in consideration is highly appreciated.
Thank you!
Edit:
Early in the morning over here and forgot to list what I need.
I need Hard Drives (Thinking of going dual Sata 300 for a Raid config), Memory, Video Card.
Budget is around $600ish? The lower it is the better it is =)
Thank you!
Edit:
