Ive been out of the game for a while but am in need of a nice little box, I only need it for light gaming, and hd video and it needs to be able to run 1920x1200 on my 24" monitor and 1900x1080 on my 50" tv.
I have A 500w power supply, Dvd burner, and a 300gb sata harddrive I do have a case as well i could use but i would prefer not to.
Heres sort of what i was looking at build wise
Video:
Radeon HD 4670 512MB 64.99-20 mir=44.99
Edit i dont need a video card As i found an ati x800 pro in a box o electronics stuff i had laying around
i liked that it had hdmi out andis fairly budget friendly as long as it will run hd video smoothly itll work for me, i think this will but i like second opinions I will likely be running both monitors consecutively
Case:
COOLER MASTER COSMOS 1000 RC going for 189.99 though i saw it a couple months ago for 140 shipped im not in any huge hurry and dont mind waiting till it drops to that pricing again
You may think its sort of stupid to want a 200 case on a 500 build but the last box i made i skimped and i tend to reuse the case while upgrading the guts farily often, needless to say i regretted not spending more on my last case.
AMD Phenom II 925 Deneb 2.8GHz Socket AM3 95W Quad-Core Processor Model HDX925WFGIBOX - Retail $240-10mir=230
I wanted to finally upgrade to quad core the problem here is this will put me about a hundred dollars over budget. I could settle for dual cora and just upgrade later but id prefer not to. So if anyone knows of anything thatd be better suited to this build comment away
Finally the ram:
CORSAIR XMS3 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 $93
What can i say its ram, corsair had been good to me in the past.
Total this comes to 596.94 - 30 in mir so about 560 -45(as i found a video card that will work) I just wanted to know if anyone knows of any better components that would be better suited to the task. Origonally my buget was 400 but after looking i decided it would be difficult to accommodate that and aquire an adequate case for future needs so i upped it and for all the good that did me im still over. I also need to pick up a copy of windows 7 for 30 from Ms which puts me back up to the 590 mark.
Video:
Case:
Finally the ram:
