MuppetMower
- Feb 13, 2009
Primarily gaming, web browsing, watching movies, listening to music, etc. I will possibly do a bit of CAD and FEA, but don’t need to focus the build on this.
$2000 counting taxes/shipping
Houston, TX, USA. There is a Microcenter very close to me.
Case
Mobo
PSU
CPU
CPU Cooler
GPU
HDD
SSD
RAM
DVD Drive(might skip. How easy is it to install windows without one?)
Monitor
Keyboard
Mouse
Decent computer speakers or headphones
Wireless Card
None
6) Will you be overclocking?
Yes. I enjoy squeezing all of the performance I can out of my CPU and, to a lesser extent, GPU.
1440 probably. I am thinking about getting the QNIX QX2710 27" Monitor, but am open to suggestions.
Within the next week
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Good overclocking performance. I don’t plan on using a RAID setup initially, but I would like to have that option in the future. I guess USB 3 and SATA 6. SLI for possible future upgrade.
No. I need an OS. Should I go with Windows 7 or Windows 8? I don’t mind learning a new OS if there are any benefits to it.
For a case, I am looking at the Corsair 650D.
I am thinking a GTX 770 would fit my budget. Should I go with the 2gb or 4gb version?
I think I'll go with a 4670k, and Microcenter has some CPU+MOBO combos that look like good deals, but I'm not sure which MOBO, if any of those, I should get.
I will probably get a Logitech G500 mouse because i used to have a G5 and I loved it. I would like a mechanical keyboard if one can be fit into the budget.
Case
Mobo
PSU
CPU
CPU Cooler
GPU
HDD
SSD
RAM
Monitor
Keyboard
Mouse
Wireless Card
None
