New build, $1500, need suggestions...
Shrane
Hello everyone. I've been a long time lurker, and before biting the bullet on a new pc build, thought it best to come here and get the community "ok". :p
I'm purchasing my parts at Newegg because quite frankly, I love them. I have a $1500 budget for my new rig. I'll be using my rig mainly for gaming, and would like to purchase an SLI board for a second video card in the future, and only intend to overclock my system very lightly. I would like to know if my list of parts would give me the best bang for the buck.
Here is what I have so far:
Antec Nine Hundred Computer Case -119.99
Seagate Barracuda 7200.11 ST3500320AS 500GB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive - OEM -124.99
EVGA 512-P3-N841-A3 GeForce 8800GTS (G92) 512MB 256-bit GDDR3 PCI Express 2.0 HDCP Ready SLI Supported Video Card - Retail - 359.99
PC Power & Cooling Silencer 750 Quad (Black) EPS12V 750W Power Supply 100 - 240 V UL, ULC, CE, CB, RoHS - Retail -169.99
CORSAIR 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail -134.00
Regarding memory, I'm not entirely sure if Corsair is the best or not, I've heard their name thrown around a bit though, along with patriot, OCZ, G.skill ect.
ASUS P5N32-E SLI LGA 775 NVIDIA nForce 680i SLI ATX Intel Motherboard - Retail -194.99
I'm not entirely sure about the motherboard either. I know EVGA has been plugged a few times around here, should I go for one of those instead?
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz 2 x 4MB L2 Cache LGA 775 Quad-Core Processor - Retail -279.99
ZALMAN CNPS9500 LED 92mm 2 Ball Cooling Fan with Heatsink - Retail -48.99
Total cost equals $1432.93
I can stick on a hundred or so if there is a part that you all think would be leagues above what I have now. Any advice, suggestions, insults...anything is more than welcome! :)
looks good. Corsair should be fine. As others will say, go with P35 chipset over 680i and get a eVga 8800GT and overclock it. But otherwise, looks good..
Corsair RAM is a good brand but often times they're a bit overpriced. In this case, all you're getting with that Corsair RAM is some fancy heatsinks. Save $35 and go with this G.Skill set:
G.SKILL F2-6400CL5D-4GBPQ 2 x 2GB DDR2 800 RAM - $105
As for SLI, I can't think of anything better to say about that than this:
Markyip1 said:
SLI is a terrible idea as an upgrade path, as a by the time you're ready to buy that second card, a newer, better card will be out that offers considerable more performance than two older cards in tandem for a similar (or sometimes cheaper) price. SLI is only needed if you want to game at 1920x1200 or above at max settings on most current games, and if your prepared to buy two cards today. Otherwise, a single card solution is better. Keep in mind that a single card solution runs cooler, is simpler to maintain, and gives you more motherboard choices.
So I recommend going with an Intel P35 motherboard. Here are some recommendations:
Gigabyte GA-P35-DS3L Intel P35 Motherboard - $86
Abit IP35-E Intel P35 Motherboard - $90
Abit IP35 Intel P35 Motherboard - $120
Gigabyte GA-P35-DS3R Intel P35 Motherboard - $130
Gigabyte GA-P35-DS3P Intel P35 Motherboard - $145
Abit IP35 Pro Intel P35 Motherboard - $168
Gigabyte GA-P35-DS4 Intel P35 Motherboard - $175
Just to help you out: If you don't need RAID, more than 4 SATA ports or legacy ports, then the IP35-E is a good choice. If you need legacy ports, than the DS3L. If you need firewire and RAID, than the IP35. If you don't need firewire but want 8 SATA ports, RAID, and legacy ports and high overclocks, than the DS3R is a good choice. If you want the DS3R but need Firewire, then go for the DS3P. If you want something that can overclock pretty damn high, than the IP35 Pro.
Also, I recommend ditching the Zalman HSF. There are much better performing HSF for the price:
Cooler Master GeminII RR-CCH-ANU2-GP HSF - $30 & 120mm Yate Loon D12SL-12 Case Fan - $3.50 x 2
Scythe SCNJ-1100P Ninja HSF - $36
Tuniq Tower 120 HSF - $45
Thermalright Ultima-90 HSF - $46 & Panaflo FBA09A12M 92mm Fan - $3
